Hello,
I have bought a used pair of the McCauley 6174 quite some time ago, and did my best to use them in an open baffle configuration (with limited success...).
But now it's time to finally put them where they belong, into a vented box. I use Unibox by Kristian Ougaard for the calculations, the ideal size would be a bit over 500 Liters... but that's a bit more than I can fit! I played around a bit with the values and ended up with a 300 Liter box with 261 Liter internal volume (deducting driver and bracing), tuned to 20 Hz, F3 should be at roughly 30 Hz (if I did this all correctly):
And here is a rendering of what it should end up looking like:
Here the baffle and bracing only:
And I hear some readers screaming "what, OSB?".
Well, to be honest, I have my doubts about that idea now. I just happen to have a bunch of it left-over at the moment. The baffle is cut from an old but nice and strong oak-veneered 3/4" plywood, it's already being glued up to the bracing:
No OSB has been used yet, so still time to re-think. When I read about gluing OSB, I found a few people saying it doesn't glue well with wood glue. One point against using OSB. Further I just think that going through all this effort building the speaker (two, actually), why not spend another 150 Euros and use some Plywood for the rest instead?
I'd love to hear your thoughts on that, and any other thoughts of course as well!
P.S.: The vented port is still missing in the drawings.
For validation purposes, I've modelled the above driver/enclosure combination using VituixCAD. The following results were obtained, and the frequency response agrees quite well. The low-frequency cut-off point pedicted by VituixCAD is a little more conservative, being 31.7Hz versus 29.9Hz predicted by Unibox. It's interesting to see that the vent output is not contibuting that greatly to the total output.
If a reasonably powerful plate amplifier is available, and it has the ability to apply a 2nd-order peaking high-pass filter, then the following extension to the bass response could relatively easily be obtained. Here is an example of the response that can be expected if a 2nd-order high-pass peaking filter with Q=2.0 set to 20Hz is used with the vented enclosure. The low-frequency cut-off has been lowered to 21.8Hz, which is about 10Hz lower than before. The driver is still working well within its linear operating range while producing a peak SPL of around 113dB in its passband.
After adding a 4th-order 80Hz Linkwitz–Riley low-pass filter, the response looks like the following. Interestingly, notice how adding the low-pass filter has slightly lowered the low-frequency cut-off point, effectively increasing the low-frequency extension by almost 1Hz.
If the listener has an aversion to port chuffing, then a sealed enclosure of the same size can produce the following response. In this design, Xmax is reached at around 21Hz, for a nominal input power of 80W re 8 ohms, while the peak power required is around 300W at 21Hz.
If a more traditional 2nd-order low-frequency roll-off is desired, we can just apply some simple parametric EQ at 23Hz, consisting of +6dB of boost with Q=2.0. The resulting simulated response is shown below. In this design, we get a little bit more output between 22Hz and 32Hz.
Fantastic responses!
First a few things that may help to understand my initial plan:
At least that's the plan. I could use digital EQ on the Raspberry (through LSP Plugins) to boost the low end I suppose?
The idea to make it a closed box is interesting. From what I've heard, it should result in a bit more controlled response, if I'm not mistaken.
Since I haven't cut the port hole yet, I wonder if I should try a closed box? I think I tried modeling the response in Unibox, and it didn't extend very low at all. I suppose in your suggestion for the closed box you assume that the lowest octave is EQ'd for the closed box design?
I wonder if I could build an active analog EQ circuit from scratch? Might be a bit above my expertise, but I am not afraid to experiment.
Thanks for your help 🙂
- The music source shall be a Raspberry Pi with the AroioDAC (already built).
- The main amp is a Musical Fidelity X-150, feeding two "satellite" speakers.
- It has a pre-amp out, which shall feed an active low-pass filter I already built. It's a forth-order with a cut-off frequency of 80 Hz.
- This low-pass filter then feeds a Musical Fidelity X-P200 power amp
- That power amp then feeds the two subs.
P.S.: The low pass filter I have built is using this module:
https://www.ebay.de/itm/176153661566?var=475601902563
That indicates the vent is too small.It's interesting to see that the vent output is not contibuting that greatly to the total output.
What type of 4th-order low-pass filter is it? Butterworth or Linkwitz–Riley?
- It has a pre-amp out, which shall feed an active low-pass filter I already built. It's a fourth-order with a cut-off frequency of 80 Hz.
If you have access to a variety of digital EQ plugins, then they could well be up to that task.At least that's the plan. I could use digital EQ on the Raspberry (through LSP Plugins) to boost the low end I suppose?
The closed-box enclosure having a more controlled response results from it having a 2nd-order low-frequency roll-off. In comparison, a vented-box enclosure has a 4th-order low-frequency response, which means that its transient response will take longer to settle.The idea to make it a closed box is interesting. From what I've heard, it should result in a bit more controlled response, if I'm not mistaken.
That's what I described. Without the presence of significant EQ, the closed-box enclosure has a higher low-frequency cut-off point than the vented box of the same volume.Since I haven't cut the port hole yet, I wonder if I should try a closed box? I think I tried modeling the response in Unibox, and it didn't extend very low at all. I suppose in your suggestion for the closed box you assume that the lowest octave is EQ'd for the closed box design?
If you have already built an active low-pass filter, then an active 2nd-order high-pass peaking filter may not be that much more complex. I expect that most of the added complexity stems from enabling the variation in 1) the peaking frequency, 2) the amount of boost, and 3) the Q of the peak. That's when having good digital EQ/filtering options available can be a bit simpler in some respects.I wonder if I could build an active analog EQ circuit from scratch? Might be a bit above my expertise, but I am not afraid to experiment.
Not necessarily. It could also be sign of a low Qts driver (which I think it is here).That indicates the vent is too small.
I think it will indeed be much easier with digital EQ, at least for testing purposes alone. I will go that route.If you have already built an active low-pass filter, then an active 2nd-order high-pass peaking filter may not be that much more complex. I expect that most of the added complexity stems from enabling the variation in 1) the peaking frequency, 2) the amount of boost, and 3) the Q of the peak. That's when having good digital EQ/filtering options available can be a bit simpler in some respects.
Regarding your calculations, I tried to replicate these with my VituixCAD installation, but didn't get quite the same results. Upon comparing the driver data, I noticed that you used an RMS of 32.56. Mine was set to 8.646, a number I found here. I admit I don't understand every bit of Thiele/Small parameters, however, when changing this value the Excursion and Impedence graphs look significantly different for the closed box. Should this be a concern? I don't want to kill the driver... I already tortured them a lot when EQ'ing in the open baffle configuration...
The Rms value that I used is relatively large, corresponding to Qms=2.9, and leads to a lower value of Qts. So the amount of damping at resonance will be much greater than in your simulation, as shown by your driver impedance and excursion peaks being considerably higher....I tried to replicate these with my VituixCAD installation, but didn't get quite the same results. Upon comparing the driver data, I noticed that you used an RMS of 32.56. Mine was set to 8.646, a number I found here. I admit I don't understand every bit of Thiele/Small parameters, however, when changing this value the Excursion and Impedence graphs look significantly different for the closed box. Should this be a concern? I don't want to kill the driver... I already tortured them a lot when EQ'ing in the open baffle configuration...
The McCauley 6174 18-inch driver seems to have a variety of Thiele-Small parameters associated with it. Hence, ideally you would at try and measure your own driver if you want the most accurate simulations when adding filtering and EQ.
From what I can see in your curves, the SPL frequency response is quite similar. So even with such a large variation in the Qms (Rms) value, the simulation should still be relatively accurate in broad terms, if not in all the fine details. Keep in mind that, with a closed-box enclosure, one would generally add lots of fibrefill material. This will also have the effect of increasing the effective enclosure volume by 10–15%, which will also change the response by lowering the closed-box resonance frequency. All of these changes are a few Hz here and there, and maybe a dB or two near the cut-off frequency, which can of course usually be equalised away if desired, as the driver can handle quite a bit of power. Of course, similar things will happen to a vented-box enclosure if we don't have entirely accurate Thiele–Small parameters.
It would be handy to be able to perform some near-field measurements of the closed-box enclosure (e.g., using a low-cost microphone). This would help to ensure that the closed-box system with EQ is performing to your satisfaction. If you already have a microphone handy, then it's worth trying to carry out a set of such measurements. A measured impedance curve would also be highly informative to see.
What worries me about the simulation with my RMS value is, that the Xmax is reached much earlier than in yours. However, I like the idea of a 2nd-order low-frequency roll-off.
Anyway, I am thinking about building it as a closed box first, test it, apply some EQ, do some measurements, and then decide whether to leave it a closed box or install a port. It would be a bit messier to install a port after the box is built, but certainly not impossible.
I have RoomEQ Wizard and a measurement mic (the MiniDSP USB). I have done measurements before, so doing it is not the issue, doing it right and understanding it is another thing 🙂
Anyway, nobody commented on the OSB vs Plywood issue. I have decided to use Plywood, which I will get on Tuesday. So it will be a few more days before the box is done.
Still working on the boxes.
Meanwhile I have a question... is it a terrible idea to put the port on the short side of the box? I realized today that I cannot route the port hole later with the way I am building the boxes. The sides are proud of the baffle and back... to protect the speaker and also the speaker connector at the back. I'd like to keep it that way.... also gives me the option to put some type of "grill" or so in the front if I decide to do so.
Hopefully I will be satisfied with the closed box frequency response, and I won't have to worry about it. But if I do decide to add a port, it would have to be on the side...
Doesn't matter what side of the box the port is on if it is not obstructed.Meanwhile I have a question... is it a terrible idea to put the port on the short side of the box?
It is far easier to cover a port rather than add it after the build is finished.
I have several cabinets that alternate between sealed or ported depending on use.
I could do that too, as I have not yet glued on the sides.Doesn't matter what side of the box the port is on if it is not obstructed.
Can you tell me how you cover your ports? Shouldn't it be a solid piece that's covering the hole, and airtight?
A few progress pictures:
The baffle is cut from what was for over 25 years my desktop... just a big piece of oak-faced plywood. Back then they sold some really good varnishes, it still looks great. Gives the speaker a bit of a vintage look already... and a history 🙂
I messed up with one of the holes I routed. I forgot to properly secure the pin of my circle jig 🙁
However, I have a very nice tight fit for the tube, so just a little bit of filler should solve this:
And this time I am using a speak-on connector. After a friend of me (a bass player) gave me crap when I used budget speaker terminals for my last subwoofer.
Can't wait to finish and test it!
Well well, I couldn't help myself and test the subwoofer with the last two sides just clamped on. The port is installed, some damping quilt on all sides etc.
I have to say, a subwoofer is quite a curious speaker. First I thought it wasn't even on. I hardly noticed any bass. I did a few tests, tried some digital EQ, which wasn't working too well, and then got my old Technics SH-9010 parametric EQ out. So I fed the lowpass filter into the EQ and raised the low frequency at around 50 Hz all the way up, which is 12 dB on this EQ. Now I finally noticed a difference...
I don't know, maybe I have too little experience with subwoofers? I expected more. However, when switching the subwoofer on and off while music was playing, I started to realize... it's really only the very low notes that make the difference in the overall sound. The bass drum, and, in some songs, e.g. Bob Marley's "Exodus" song, you really notice it.
I expected more. But then again, it definitely sounded much fuller with the subwoofer on. It still puzzles me why this driver, which is supposed to have 95 dB sensitivity, needs so much boost. The "satellite" speakers I used for this test were some old simple Infinity bookshelf speakers. I don't know their sensitivity, but I cannot imagine it's much more than 90.
Any thoughts on this? Am I demanding too much bass maybe?
Everyone's hearing is different, but to hear low frequencies at the same level as higher frequencies requires far more SPL. The disparity between low frequency and high frequency is greater at lower listening volume, as can be seen in the red "Equal Loudness Contour" lines in the chart below)Any thoughts on this? Am I demanding too much bass maybe?
For example, ~90dB SPL would be required to hear 50Hz at the same "loudness" as 1kHz at only 60dB.
60dB at 1kHz is "conversational level".
At ~20Hz, most people need around 80dB to even hear the low frequency content.
The port puts out most of the SPL at the tuning frequency (Fb), you chose to use a very small port relative to the speaker's displacement. At higher drive levels, the port will be "blown out", making more wind noise than bass output.
That said, most musical bass content is above 30Hz, output will be limited to the McCauley 6174's displacement or the amplifier's voltage and current potential.
Art
Thanks for the detailed answer.
Regarding the port, I haven't noticed any port noise, even at higher volumes.I somehow thought this was already a big port at 100mm...?
Loudness and how we perceive sound has always fascinated me. The LSP Plugins for Linux actually have a variable loudness plugin, and I find it makes a huge difference in sound, much nicer, especially at lower volumes.
I have listened a bit more now, and there are a couple of other factors that came to mind:
I'll be patient now and keep the construction going... the next test, with two subwoofers, will certainly be quite satisfactory.
- I was only using one subwoofer... once two are in place, the low frequencies will of course be elevated.
- below 80 Hz is not that much happening in most music I listen to. When I played some more modern stuff, especially hip-hop or things like "Dis is da Drum" from Herbie Hancock, you really start hearing (and feeling) those notes below 80 Hz.
- Subwoofers
- 300 Litre subwoofer for McCauley 6174 in the making...
