An Idea for a 6N1P-6N6P / 6H1∏-6H6∏ OTL Headphone Amp
Greetings, Friends. I've long wanted to build a simple headphone amp using the Soviet 6N6P double triode as output. Seeing the earlier post of a Morgan Jones 6DJ8 Headphone Amp - style build completed with 3x 6N1P tubes inspired me to whip up a schematic for a similar circuit.
Adapted from the Optimized Morgan Jones Headphone Amplifier circuit. R4 & R5 prob need to be adjusted to equalize voltages across each triode. Not sure about bypass caps.
Power Supply, expected voltages in Blue:
Most of the power supply designs from the original Headwize page feature CRC filters for the HT and a cap to float the LV. I'd rather use a traditional voltage divider to elevate the heater supply about 72v. Will this work as drawn? Do I need a cap somewhere in there?
Any advice on the subject welcome, thanks for taking a look!
w
Dubadub, you didn't specify what impedance 'phones you plan to use. This type of circuit might not do to well with low impedance, low efficiency 'phones. Think planars, or some low imp. dynamics. 366 volts B+ sounds a bit high. You might need to put a cap across the 68K, 3W resistor in the PS to minimize hum. A 280 volt AC, bridge rectified, secondary might made more DC than you want or need.
