Too much noise and distortion out of ADC fed with guitar signal
This is a sample of the DAC output through my audio interface (lower your volume):
https://drive.google.com/file/d/1fVYVZq81MRJWpyGOoc1MXEjnBV_QT7qb/view?usp=sharing
This has an EQ filter applied, the raw output is much much worse (only that background noise can be heard).
You have serious problems. You need decent I2S signals to drive the dac. Then maybe just send it a test tone or something, or maybe just silence at first. Keep it real simple to find out where the problem is. If your I2S signals are full of jitter and noise then no surprise if it sounds grossly unacceptable. Look at the datasheet for the dac. It should show you what the waveforms need to look like. If you can get the dac working, then try to add the ADC and see what that does.
Remember, you are dealing the real, serious RF. Edge rates (risetimes) can involve Fourier frequency components up into the hundred's of MHz. You need a proper 4-layer PCB with a ground plane. It may never work with solderless breadboards.
Maybe try studying the attached.
Do you think a single/dual layer PCB will at least make it acceptable? I'll be etching a board myself.
These pictures look to me as signatures of data alignment mismatch. Group of samples that supposed to be below zero “jump” to higher codes. I am guessing that ine of the devices sends/receives left justified, another - i2s (msb shift)
I tested switching the FMT of the DAC and still no success. I guess the FMT matching is not the issue.
You should get this to work without PCB provided you keep the I2S wiring short (< 10cm).
Make ADC the master. Use a common ground for all boards (MCU, ADC, DAC).
Feed MCK (12.288MHz) from PC4 to ADC with a short wire.
Feed SCK, BCK, LRCK and DIN from ADC to DAC with short wires.
If this does not work or improve ADC data output it is possible that your ADC board does not work. Making a PCB does not help then.
Thanks for the help guys, you have been really hepful.
A little update: I tested using a PCM3060 codec, and I got the same behavior. I guess that excludes faulty ADC/DAC and shows that there really is a problem with the MCK clock path. I'll post an update when I have the board ready.
Hi guys. I etched a board using now a PCM3060 audio codec, but I still have that same issue:
44.1kHz, 24 bits, STM32 master
Plus, I have no DAC output from the codec when trying to transmit a fixed value to the DIN pin. VoutL+ stays fixed at 2.4V (as the datasheet states - DAC output is centered around 0.5*VCC, and because of that, I was expecting to get a constant DC value above 2.4V):
C:
/* USER CODE BEGIN Header */
 * @file           : main.c
 * @brief          : Main program body
 * @attention
 * Copyright (c) 2025 STMicroelectronics.
 * All rights reserved.
 * This software is licensed under terms that can be found in the LICENSE file
 * in the root directory of this software component.
 * If no LICENSE file comes with this software, it is provided AS-IS.
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
#include <math.h>
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
#define SAMPLE_RATE      44100
#define BUFFER_SIZE      512
#define DAC_MAX          0x7FFFFF
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
I2S_HandleTypeDef hi2s2;
DMA_HandleTypeDef hdma_spi2_rx;
DMA_HandleTypeDef hdma_spi2_tx;
QSPI_HandleTypeDef hqspi;
/* USER CODE BEGIN PV */
int32_t buffer[BUFFER_SIZE];
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MPU_Config(void);
static void MX_GPIO_Init(void);
static void MX_DMA_Init(void);
static void MX_I2S2_Init(void);
static void MX_QUADSPI_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
void generate_test_tone(void) {
    for (int i = 0; i < BUFFER_SIZE; i++) {
        // PCM3060 expects 24 bit data aligned to the left inside a 32 bit word
        buffer[i] = DAC_MAX << 8;
/* USER CODE END 0 */
 * @brief  The application entry point.
 * @retval int
int main(void) {
    /* USER CODE BEGIN 1 */
    /* USER CODE END 1 */
    /* MPU Configuration--------------------------------------------------------*/
    MPU_Config();
    /* MCU Configuration--------------------------------------------------------*/
    /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
    HAL_Init();
    /* USER CODE BEGIN Init */
    /* USER CODE END Init */
    /* Configure the system clock */
    SystemClock_Config();
    /* USER CODE BEGIN SysInit */
    /* USER CODE END SysInit */
    /* Initialize all configured peripherals */
    MX_GPIO_Init();
    MX_DMA_Init();
    MX_I2S2_Init();
    MX_QUADSPI_Init();
    /* USER CODE BEGIN 2 */
    generate_test_tone();
    HAL_I2S_Transmit_DMA(&hi2s2, (uint16_t*) buffer, BUFFER_SIZE);
    /* USER CODE END 2 */
    /* Infinite loop */
    /* USER CODE BEGIN WHILE */
    while (1) {
        /* USER CODE END WHILE */
        /* USER CODE BEGIN 3 */
    /* USER CODE END 3 */
 * @brief System Clock Configuration
 * @retval None
void SystemClock_Config(void) {
    RCC_OscInitTypeDef RCC_OscInitStruct = { 0 };
    RCC_ClkInitTypeDef RCC_ClkInitStruct = { 0 };
    /** Supply configuration update enable
    HAL_PWREx_ConfigSupply(PWR_LDO_SUPPLY);
    /** Configure the main internal regulator output voltage
    __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
    while (!__HAL_PWR_GET_FLAG(PWR_FLAG_VOSRDY)) {
    /** Initializes the RCC Oscillators according to the specified parameters
     * in the RCC_OscInitTypeDef structure.
    RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
    RCC_OscInitStruct.HSEState = RCC_HSE_ON;
    RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
    RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
    RCC_OscInitStruct.PLL.PLLM = 5;
    RCC_OscInitStruct.PLL.PLLN = 160;
    RCC_OscInitStruct.PLL.PLLP = 2;
    RCC_OscInitStruct.PLL.PLLQ = 4;
    RCC_OscInitStruct.PLL.PLLR = 2;
    RCC_OscInitStruct.PLL.PLLRGE = RCC_PLL1VCIRANGE_2;
    RCC_OscInitStruct.PLL.PLLVCOSEL = RCC_PLL1VCOWIDE;
    RCC_OscInitStruct.PLL.PLLFRACN = 0;
    if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK) {
        Error_Handler();
    /** Initializes the CPU, AHB and APB buses clocks
    RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_SYSCLK
            | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2 | RCC_CLOCKTYPE_D3PCLK1
            | RCC_CLOCKTYPE_D1PCLK1;
    RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
    RCC_ClkInitStruct.SYSCLKDivider = RCC_SYSCLK_DIV1;
    RCC_ClkInitStruct.AHBCLKDivider = RCC_HCLK_DIV2;
    RCC_ClkInitStruct.APB3CLKDivider = RCC_APB3_DIV2;
    RCC_ClkInitStruct.APB1CLKDivider = RCC_APB1_DIV2;
    RCC_ClkInitStruct.APB2CLKDivider = RCC_APB2_DIV2;
    RCC_ClkInitStruct.APB4CLKDivider = RCC_APB4_DIV2;
    if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK) {
        Error_Handler();
 * @brief I2S2 Initialization Function
 * @param None
 * @retval None
static void MX_I2S2_Init(void) {
    /* USER CODE BEGIN I2S2_Init 0 */
    /* USER CODE END I2S2_Init 0 */
    /* USER CODE BEGIN I2S2_Init 1 */
    /* USER CODE END I2S2_Init 1 */
    hi2s2.Instance = SPI2;
    hi2s2.Init.Mode = I2S_MODE_MASTER_FULLDUPLEX;
    hi2s2.Init.Standard = I2S_STANDARD_PHILIPS;
    hi2s2.Init.DataFormat = I2S_DATAFORMAT_24B;
    hi2s2.Init.MCLKOutput = I2S_MCLKOUTPUT_ENABLE;
    hi2s2.Init.AudioFreq = I2S_AUDIOFREQ_44K;
    hi2s2.Init.CPOL = I2S_CPOL_LOW;
    hi2s2.Init.FirstBit = I2S_FIRSTBIT_MSB;
    hi2s2.Init.WSInversion = I2S_WS_INVERSION_DISABLE;
    hi2s2.Init.Data24BitAlignment = I2S_DATA_24BIT_ALIGNMENT_LEFT;
    hi2s2.Init.MasterKeepIOState = I2S_MASTER_KEEP_IO_STATE_DISABLE;
    if (HAL_I2S_Init(&hi2s2) != HAL_OK) {
        Error_Handler();
    /* USER CODE BEGIN I2S2_Init 2 */
    /* USER CODE END I2S2_Init 2 */
 * @brief QUADSPI Initialization Function
 * @param None
 * @retval None
static void MX_QUADSPI_Init(void) {
    /* USER CODE BEGIN QUADSPI_Init 0 */
    /* USER CODE END QUADSPI_Init 0 */
    /* USER CODE BEGIN QUADSPI_Init 1 */
    /* USER CODE END QUADSPI_Init 1 */
    /* QUADSPI parameter configuration*/
    hqspi.Instance = QUADSPI;
    hqspi.Init.ClockPrescaler = 255;
    hqspi.Init.FifoThreshold = 1;
    hqspi.Init.SampleShifting = QSPI_SAMPLE_SHIFTING_NONE;
    hqspi.Init.FlashSize = 1;
    hqspi.Init.ChipSelectHighTime = QSPI_CS_HIGH_TIME_1_CYCLE;
    hqspi.Init.ClockMode = QSPI_CLOCK_MODE_0;
    hqspi.Init.FlashID = QSPI_FLASH_ID_1;
    hqspi.Init.DualFlash = QSPI_DUALFLASH_DISABLE;
    if (HAL_QSPI_Init(&hqspi) != HAL_OK) {
        Error_Handler();
    /* USER CODE BEGIN QUADSPI_Init 2 */
    /* USER CODE END QUADSPI_Init 2 */
 * Enable DMA controller clock
static void MX_DMA_Init(void) {
    /* DMA controller clock enable */
    __HAL_RCC_DMA1_CLK_ENABLE();
    /* DMA interrupt init */
    /* DMA1_Stream0_IRQn interrupt configuration */
    HAL_NVIC_SetPriority(DMA1_Stream0_IRQn, 0, 0);
    HAL_NVIC_EnableIRQ(DMA1_Stream0_IRQn);
    /* DMA1_Stream1_IRQn interrupt configuration */
    HAL_NVIC_SetPriority(DMA1_Stream1_IRQn, 0, 0);
    HAL_NVIC_EnableIRQ(DMA1_Stream1_IRQn);
 * @brief GPIO Initialization Function
 * @param None
 * @retval None
static void MX_GPIO_Init(void) {
    GPIO_InitTypeDef GPIO_InitStruct = { 0 };
    /* USER CODE BEGIN MX_GPIO_Init_1 */
    /* USER CODE END MX_GPIO_Init_1 */
    /* GPIO Ports Clock Enable */
    __HAL_RCC_GPIOE_CLK_ENABLE();
    __HAL_RCC_GPIOH_CLK_ENABLE();
    __HAL_RCC_GPIOC_CLK_ENABLE();
    __HAL_RCC_GPIOB_CLK_ENABLE();
    __HAL_RCC_GPIOD_CLK_ENABLE();
    __HAL_RCC_GPIOA_CLK_ENABLE();
    /*Configure GPIO pin Output Level */
    HAL_GPIO_WritePin(GPIOB, LED_RED_Pin | LED_GREEN_Pin, GPIO_PIN_RESET);
    /*Configure GPIO pin : FSWITCH_Pin */
    GPIO_InitStruct.Pin = FSWITCH_Pin;
    GPIO_InitStruct.Mode = GPIO_MODE_IT_RISING_FALLING;
    GPIO_InitStruct.Pull = GPIO_PULLUP;
    HAL_GPIO_Init(FSWITCH_GPIO_Port, &GPIO_InitStruct);
    /*Configure GPIO pins : LED_RED_Pin LED_GREEN_Pin */
    GPIO_InitStruct.Pin = LED_RED_Pin | LED_GREEN_Pin;
    GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
    GPIO_InitStruct.Pull = GPIO_NOPULL;
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
    HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
    /* EXTI interrupt init*/
    HAL_NVIC_SetPriority(FSWITCH_EXTI_IRQn, 0, 0);
    HAL_NVIC_EnableIRQ(FSWITCH_EXTI_IRQn);
    /* USER CODE BEGIN MX_GPIO_Init_2 */
    /* USER CODE END MX_GPIO_Init_2 */
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
/* MPU Configuration */
void MPU_Config(void) {
    MPU_Region_InitTypeDef MPU_InitStruct = { 0 };
    /* Disables the MPU */
    HAL_MPU_Disable();
    /** Initializes and configures the Region and the memory to be protected
    MPU_InitStruct.Enable = MPU_REGION_ENABLE;
    MPU_InitStruct.Number = MPU_REGION_NUMBER0;
    MPU_InitStruct.BaseAddress = 0x0;
    MPU_InitStruct.Size = MPU_REGION_SIZE_4GB;
    MPU_InitStruct.SubRegionDisable = 0x87;
    MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL0;
    MPU_InitStruct.AccessPermission = MPU_REGION_NO_ACCESS;
    MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_DISABLE;
    MPU_InitStruct.IsShareable = MPU_ACCESS_SHAREABLE;
    MPU_InitStruct.IsCacheable = MPU_ACCESS_NOT_CACHEABLE;
    MPU_InitStruct.IsBufferable = MPU_ACCESS_NOT_BUFFERABLE;
    HAL_MPU_ConfigRegion(&MPU_InitStruct);
    /* Enables the MPU */
    HAL_MPU_Enable(MPU_PRIVILEGED_DEFAULT);
 * @brief  This function is executed in case of error occurrence.
 * @retval None
void Error_Handler(void) {
    /* USER CODE BEGIN Error_Handler_Debug */
    /* User can add his own implementation to report the HAL error return state */
    __disable_irq();
    while (1) {
    /* USER CODE END Error_Handler_Debug */
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t *file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
I am only hearing the raw guitar signal.
Like bohrok2610.and eclipsevl, I think it is a data integrity issue. For some reason the sign bit is sometimes read as 0 when it should be 1, causing a jump of +223. If that happened all the time, it could be due to incompatible formats, but it appears to be sometimes right and sometimes wrong.
Depending on how fast the logic is and if your clock and data lines are longer than a few centimetres, it might be necessary to add series termination resistors near the sources of the clock and data signals to get rid of transmission line resonances. At least I had some really weird issues due to transmission line resonances when I was working on a perfboard-and-adapter-boards version of the digital part of my valve DAC, a couple of series resistors solved those. If the layout is such that the return currents of the digital signals have to take a large detour, it might be necessary to add a few ground jumpers to solve that.
Could you show the layout of the clock and data lines?
Regarding your schematic, I assume you put the DAC in a mode where it gets its word and bit clock from the ADC and that using the CODEC reset input is optional. Is that correct?
R23 appears to be about 20 times too small for an electric guitar input. R25 appears to be generating thermal noise without doing anything useful (I assume dithering is taken care of inside the CODEC chip).
There is no series resistor between U7A and the output. A resistor of 100 ohm or so might be needed for stability when you drive a long cable.
Is there power supply decoupling close to the microcontroller?
