For Sale JohnAudioTech JAT501 Class AB Amplifier PCB pair -- LAST ONE
Things you have for sale.
JohnAudioTech JAT501 Class AB Amplifier PCBs from JLCPCB
4 of 5 pairs sold. Last final set remaining.
$10 Canadian plus shipping.
Made from JohnAudioTech's publicly available JAT501 gerber files.
No modifications to John's design were made.
Inline layout, board revision 1.1
High quality PCBs. Standard 1.6 mm thickness, and completely flat.
Two layer, double sided, blue solder mask.
This sale is not for profit. It is being offered as a service to the community. And to help promote John's channel.
These are just the bare PCB boards. You have to source your own components, assemble, and test.
Bill of Materials (BOM) including part numbers is also provided.
Includes two hand made and tested Thiele network coils (labeled L1)
Shipping within Canada is $3.00 using Canada Post oversized letter mail (sorry no tracking).
Shipping to USA is $10.00 using Canada Post Tracked Packet - USA. Includes a tracking number.
Known issue, the board stencil has some typos.
Transistors labeled 2N5551C should read 2N5551.
Transistors labeled 2N5401C should read 2N5401.
The "C" variant has a different pinout.
2N5551 / 2N5401 (1. Emitter 2. Base 3. Collector)
2N5551C / 2N5401C (1. Emitter 2. Collector 3. Base)
One board has scratched solder mask that happened at the factory. The exposed copper was tinned. The traces are ok. See attached photos.
Reactions: turion64
Linear power supply and soft start PCBs designed by CBZ Project also available. Combined shipping on multiple items.
PCBs sold at cost. No profit from the sale of items designed by others.
The PCBs are stenciled for 220 volts, but can be used with 110-120 volts if the dropper and filter capacitors are replaced with different values.
Also the PCB is stenciled for 10,000uF / 100V filter/smoothing capacitors. Less capacity and lower max voltage capacitors can be used instead.
Update: all of the smaller Softstart boards are sold out. The JAT501 boards and larger PSU with Softstart boards are still available.
Example of the JAT501 boards and PSU board together in one project.
More options available:
  1. JAT501 boards, coils, and CBZ Project PSU board with soft start.
  2. JAT501 boards, coils, and ebay PSU board no soft start.
  3. JAT501 boards, coils, and ebay PSU board no soft start. PSU board as a kit.
Made from JohnAudioTech's publicly available JAT501 gerber files. No modifications to John's design were made. Inline layout, board revision 1.1, two layer, double sided, and blue solder mask.
$10 Canadian plus shipping. This sale is not for profit. It is being offered as a service to the community. And to help promote John's channel.
**** Note — This is a sharing article and does not represent anyone's situation.
The JohnAudioTech JAT501 is a DIY Class AB audio amplifier designed by John, a well-known figure in the audio DIY community. He’s shared positive experiences building the JAT501 and praised how easy it is to follow his instructional videos.
The JAT501 offers a strong foundation for anyone interested in building a high-quality Class AB amplifier. Its open-source design encourages both customization and learning, making it a great choice for hobbyists at any level.
But despite the quality of projects like this, DIY audio gear is often undervalued. Even well-made, high-performance amps sometimes struggle to gain attention or fair pricing. Here’s why:
  • Lack of Brand Recognition
    People often rely known brands, even if a DIY project matches or exceeds their quality.
  • Perceived Risk
    Buyers worry: “What if it breaks? Who will fix it?” That uncertainty can be a big turn-off.
  • Limited Exposure
    DIY builders usually sell through forums or local listings, reaching only groups—often other builders who aren't looking to buy.
  • Invisible Labor
    A builder might spend 40+ hours on an amp, but buyers don’t see that. They compare it to commercial gear without recognizing the effort or craftsmanship behind it.
  • Price Anchoring
    People often compare DIY prices to factory-made gear, not realizing handmade amps may use higher-quality parts and better construction.
  • Fear of Non-Standard Design
    Some buyers assume DIY gear isn’t safe enough or properly designed, even when that’s not the case.
Still, DIY builders can increase buyers' interest and trust by:
  • Sharing builds and walkthroughs on YouTube or forums
  • Offering demos or sound tests
  • Highlighting premium components and unique features
That said, it’s challenge to sell DIY builds unless those build a strong reputation or turn their hobby into a business.
Reactions: spippy71
