Cosmos APU a notch+LNA $70 to outperform APx555b for $30,000
Tried the LPF yesterday with REW
Just with ASUS U7 -> LPF ->ADCiso. Balanced. That is L+R out, R inverted
The ASUS has about -105 dBFS THD up to 1 k, then it rises. Maybe -90dBFS @ 20k
With LPF it benefits from
  • Even harmonics cancelled about 50 dB on my card
  • 3rd harmonic attunated about -18 dB
  • The output of the LPF can drive the ADC-iso on 640R setting.
So a very good solution to get a old/mediocre DAC "up to medium speed"
I used the 1.7 Volt setting on the ADC. Guess I am more interested in closer to 0 dBu values. That is around 1 volt out. Not 9 V ;-)
With a SMSL 39pro I get about -132dB 3rd with same setting on ADC. Not much difference with or without LPF. Maybe 3 to 5 dB better with LPF
That is OK by me
Yes quite nice.
ADAU1452 generating sin wave and compensating 3rd harmonic with a x^3 addition at about -80 dB
The DAC is a Cirrus logic codec about 10 years old. Analog output filter removed from DAC board.
Still 1,7V setting on ADC. 2 channels used on codec/DAC, one inverted.
Is your ADC marked as "THD+" on the bottom? H3 -148db isn't an average performance for Cosmos ADCiso, if I see such a unit I mark it "THD"(all harmonics -140db) or "THD+"(-145db and lower). The worst unit has H3 -133-134db, average about -136-138db, H2 is always <-140db. I measure/calibrate ADCs at +27C and 768k. 768k makes the ADC chip warmer and harmonics lower.
Well, I've tested 14pcs and found LPF itself is nearly perfect but Bal/Unbal stage isn't. As it was expected the least reliable parameter is H2, any lack of symmetry leads H2, so I recommend using Bal/Unbal stage with THD tuning(9039S + 9039_Tweak.exe).
Regarding the Bal/Unbal stage. I get just 18dB of rejection when I try in two in phase sin wave. LPF part has about 50 on my setup.
So something has to be wrong. Measured the resistors and found the answer? Wrong values at some of the resistors?
They match very well, by the way, the ones with same value, that is.
