I was wondering if anybody had some kicking around they could trade or sell. I have four but need more.
Cheers.
Cheers.
These are similar, but they want you to buy 13 minimum @ $22.10 each.
https://www.onlinecomponents.com/en/productdetail/chemi-con/e36d630hpn223mc67u-54626053.html
I think, you misread the site.....These are similar, but they want you to buy 13 minimum @ $22.10 each.
Minimum 13 pieces, IF they´re OUT of stock.
But they are not. They have 44 in stock.
Wouldn´t make much sense to advertize 1/5/10-piece price otherwise??😀
Wünderbar!STOXX is in luck then.
Case closed with a slight spec change in temperature. Fine by me.
Cheers.
I'll get a price from RM if he has time for a PM.
Wünderbar!
I would double check the terminal spacing, the diameter and length, if critical.
I did indeed. They are the same as far as the data sheets say. I shall check again.I would double check the diameter and length, if critical.
RM's caps would be so much better but this project can not afford the extra indulgence.
