Noisy NAD 7240PE - how to diagnose issue?
Hi everyone - So I have this NAD 7240PE. It's an absolute beast of a receiver that I bought sight unseen from the other side of the country and it arrived pretty beat up. It was super dirty and dusty inside and noisy as hell and the seller proceeded to never return any of my messages 😅. Several of the largest caps had burst at some point and spilled their goop on the PCB, which itself has turned brown from heat in the amp section, it must have been run HOT a lot. The radio tuner side meanwhile is still green as a normal PCB and works pretty well even just using the built in FM antenna.
I switched out the busted caps and cleaned it up and it's working a lot better but there must still be some component(s) fried or something since the amp has a ca. 10 sec period at startup and turn off where it plays this kind of ground saw wave noise through the speakers similar to touching an input jack your finger. After that stops, there is still this random, intermittent popping sound in both channels underneath the audio signal but it decreases slowly until - when the amp is warmed up perhaps - the noise is gone. At this point, the amp works almost noiselessly and sounds absolutely superb.
I'm telling you, the combination of buttons called “Bass EQ” and “Loudness” really make this amp drive way more nice low-end from my two Artcoustic wall mounted speakers than my other, newer NAD C316BEE ever could. It also sounds much more dynamic and enjoyable, no doubt partly due to the pretty complex BJT-based Class G topology in which separate higher voltage power rails are switched to momentarily when triggered by a powerful enough input signal, ultimately resulting in higher efficiency and dynamic range I believe.
Anyway, in my search for knowledge that could help in diagnosing and fixing the issue, I came upon some 7240PE repair threads on here and some people (e.g. Mooley) seem to have the skillset and experience needed to diagnose this kind of stuff so here I am, asking for some tips on what to look into on this amp 🙂
I can record the noises in question if it helps, as well as measure anything with a multimeter. I also have a power supply and even an old analog Agilent Oscilloscope that I bought cheap from my old student job employer (ICEPower) as they had stopped using it in favor of the new digital ones. It has been sitting in a cabinet unused since because I have yet to buy some probes for it - which I will if it will help fix this amp!
P.S. Here's the service manual which includes the amp schematic on page 13 and here's also some technical info on how the Class G voltage switching works for those interested:
Hi kapitiaudio,
Thanks for the advice. Firstly, I just realized that the 3240PE schematic I included in the original post looks a bit different to the 7240PE one (although it is purportedly the same amp section) so I've replaced it with the 7240PE service manual which includes its schematic on page 13.
I had already replaced the busted caps that I could see and touched up some random suspect solder joints earlier but I will do another thorough round of visual inspection to make absolutely sure everything looks in order.
Regarding checking the power supply voltages, just to be sure, does this involve measuring the voltage of the marked points in the schematic screenshot below with the amp turned on and checking if the measured voltage matches the voltage indicated on the schematic? If so, is there anything I should watch out for to avoid accidentally ruining the amp with the multimeter leads - besides just not shorting anything? Lastly, how do I check the ripple levels? Is that related to the main amp alignment procedure on page 5 in the service manual?
Yes you've got the right idea for measurement points. You measure ripple level with the oscilloscope. You have to be extremely careful with multimeter probes, it's so easy to slip and short something out.
One thing you can do is get some spring loaded hook on probes for your multimeter, then attach them to the desired measurement point when the amplifier is off. Then switch it on. Take the measurement and then turn it off. You can repeat this process for each measurement. This is fairly safe and far less prone to slippage, but it may pay to wait a 1 min before and after each measurement to allow the capacitors to discharge a bit. I use this method if the measurement points are not readily accessible.
I have repaired my 7240PE, but ended up replacing a lot of the small capacitors. I would replace C515-C518, all four of them. This amplifier have 2 jumpers on the back for separating pre/power stage so its easy to just test each part of the amplifier to reduce fault finding.
Reactions: jordheis
@kapitiaudio, while waiting for the capacitor replacements recommended by Jakobsson, I've checked the power supply voltages by measuring the voltage over capacitors:
20 V supply:
C517: 19.7 V
C518: 19.4 V
43 V supply:
C505: 40.2 V
C506: 40.4 V
71 V supply:
C509: 77 V
C510: 77 V
and I checked the +28 V point by measuring the voltage from the collector of Q501 to the negative leg of C513, this was 32 V. The -28V point is 31.7 V, measured from the collector of Q502 to the positive leg of C514.
Might we be able to deduce anything by the discrepancies present on the 28 V, 43 V and 71 V supplies?
@Jakobsson, I just switched out C515-C520 and the the startup ground-like noise is way quieter now and only goes for 1/3 as long as before so replacing them definitely seems to have had a positive effect even though it's still present. I appreciate the help nonetheless, thank you.
@kapitiaudio, I checked the DC offset, it seems to be around -85 mV on the right channel and 0 mV on the left. I have ordered a probe for my oscilloscope but it won't arrive for a few weeks. I'll post again on here about the supply ripple levels and the startup noise once I receive it and test with it.
20 V supply:
C517: 19.7 V
C518: 19.4 V
43 V supply:
C505: 40.2 V
C506: 40.4 V
71 V supply:
C509: 77 V
C510: 77 V
I have some Technics amplifiers that have to primary mains voltage settings that are quite close together. If you have similar options a previous owner might have chosen the highest of two close similar voltage ratings to extract more power output for your amplifier. I would query the ac winding for the 71volt supply. The risks of higher voltage supplies are greater than those of the lower supplies
If the startup noise occurs on both channels, then the slightly high DC offset won't be the cause. Get the scope on the output, you need to see what's going on.
@kapitiaudio, what is the correct/safe way to measure the output of this particular amp? Do I just connect the probe ground to the black speaker output and the probe to the red? Should I leave the speakers connected as well during the measurement or do I need to use a resistor as a dummy load instead?
Also, where should I be measuring the power ripple?
Thanks in advance for the help, I've been googling these topics but the variety of methods and scenarios I've found leaves me worried that I might ruin something if I go trying stuff all willy-nilly.
You can just use a multimeter across the speaker terminals set to VDC. You'll need to wait for the relays to click before you get a reading. Use the volts range first, then if it's small, set to mV range to get a better reading. Should be no more than +/-50mV.
Power ripple is measured the same place as the power supply voltages, but you'll need an oscilloscope instead of a voltmeter.
I just re-read your initial description. Before you do anything else, remove any brown gunk stuck to the PCB and clean up the boards. This stuff is notorious for causing obscure faults.
I've cleaned the brown gunk as well as I can without removing a bunch of components, hopefully what's left isn't causing any problems. Is the idea that the gunk might be shorting between components and thus causing unpredictable behavior?
What I'm unsure about is whether or not I should have the speakers connected when measuring the the startup noise and intermittent noise with the oscilloscope on the speaker outputs.
@kapitiaudio, here are some oscilloscope power supply measurements of the same points as in my earlier multimeter measurement reply.
This is the voltage over C509 - The ripple seems to be about 141 mV which, from what I gather, is quite high.
Zooming out on the time scale, it does fluctuate quite a bit, around 0.5 V, in a seemingly random manner:
Measuring C505 and C506 shows some ripple as well although its only about 10 mV:
Yes the gunk can become conductive over time with heat. Just get rid of it all if possible.
Never connect the speakers if you don't have to. If anything goes wrong while troubleshooting your speakers could be at risk. Also it reduces the stress on the output stage should something not be quite right.
The ripple levels look fine, but the first scope shot looks a bit strange. I'd expect a nice regular ramp like the bottom picture. Are you sure you were earthing the scope properly?
Anyhow, good that you now have a scope on the job! Stick it on the speaker output while it's making the noise and let's see what's there...
@kapitiaudio, I'm not sure if I was earthing the scope properly, I simply connected the ground lead of the probe to one lead of the capacitor and the actual proble to the other.
In any case, here's the startup/shutoff noise on the speaker output:
The left edge of the large central waveform is where I turn on the amp and the right edge is where the noise stops on its own accord.
Here it is zoomed in:
Looks like a noisy sine wave.
Zoomed in even more:
We can see some noise superimposed on that 50 Hz sine.
Here's that right edge from the first photo in this post, where the noise stops:
Can these measurements provide any insight into the cause(s) of the noise?
