Electrocompaniet EC-3 and ECMC-1, schematics wanted
Dear all,
I am looking for schematics from mentioned Preamp and Step-up board. Main pre is working OK, with Line inputs, but phono one have problem. Since ECMC-1 is a step-up board, I cannot check it either. I contacted mother company but they told me it is not in their policy to share such service information...
I would appreciate if someone has drawings (is OK in scan or photo) to help me out to repair it.
Best regards,
John
I don’t have schematics but I have one unused ECP-1 board and also a EC3 RiAA board.
PM if interested.
R
Thanks for replies guys, appreciated. I sent to Terje Sandstrøm and waiting for his reply and assistance. Meanwhile, Electrocompaniet replied once more that they cannot help me more either...
@RM boards you have don't fit to my pre unit.
I am still searching...
John
Phono input; right chanel is dead, left one is performing low, hardly hear. I cannot check step-up board since it is using MM part which seems faulty. I do agree with you, heat inside is too high! In some areas, printed board discolored because of this. I checked for dry joints or bad caps. But schametics are crusial for doing more targeted measurements to find weak parts and points.
John
Maybe I didn't describe well what I have in my hands... So, yes, MM stage is faulty. Preamp has a MM stage in its main board. Also a has connector that drives signal from RCA inputs to MM board -OR- through MC step-up board.
Pictures later this afternoon.
John
Thansk a lot! Have you the rest of drawings??? Maybe is a good chance to check the rest of operation, or to be ready in a future failure case!
John
If you are thinking of the headamp, I'm afraid not. However, I know that the ECMC-1 is a development of the ECMC board from the EC-1 amp, they have much in common. Gives you one more option to search for, maybe.
Pictures I promised. Boards are almost toasted... The next big challenge is to connect all trafos' cables outside box for testing...
John
