Output tube distortion comparison
Joined 2015
I have few different sets of output tubes and I perceived differences in sound so I measured the distortion under the same operating conditions. The amplifier is a PP UL with A431 style OPT, 470V B+, 15dB gNFB and the tubes biased for 20W each at idle. The graphs are distortion sweeps at 5W into a non-inductive 8ohm load. The %THD legends are measured at 1kHz.
Last of all I did the same test with a Firstwatt J2, 5W into a 8ohm non-inductive load
I don't think I'm trying to achieve the best THD measurement, but more trying understand how different HD responses are perceived and why certain combinations may be preferred. The J2 has a fairly flat HD response and it doesn't sound bad, and my Purifi amp also doesn't sound bad and measures extremely low THD.
Yes, try again with the bias at 55mA. Also your second harmonics are high, it is possible that the bias is not set perfectly right and that doesn't cancel out 2nd harmonics
In my recent tests at a lower B+ I obtained 0.02THD total at 5 Watts, only 3rd harmonics.
Imo, the lower the better, it is more important in the 60 - 500 hz region especially IMD, the THD figures are simply an indication of the performance of the circuit.
When I changed the UL to pentode it made a huge difference in clarity and coherence in the sound. I never though it would be the sound which I always sought, a full, analytical and truth sound where I can listen to as many things at the same time.
My solid state is a bit like that too. I found class T sound way too soft and lethargic. The only tube which I like is the kt120.
Reactions: longspeak
Do the tubes have individual bias voltages or is it shared?
The grid bias voltages are individually controlled, good question.
You should do these tests at also 50hz and 10khz to get a better idea.
The tests are a sweep, 20Hz-48kHz signal - maybe I don't understand your suggestion? I do like the idea of an IMD test, what do you suggest for frequencies and balance?
Here are the measurements at 55mA, the B+ dropped to 455V
Reactions: decramer
I agree with Peter Tub, and the other who says the feedback works wonders, why?
The thd is quite high and looks like transformer limitation by the shape of the curves, some ringing or reactance, It could be the transformer limitation which the feedback is unable to correct with phase shifts not 180 in all spectrum
Try disconnecting all feedback and measure again, it would be appreciated!!
