OPT impeadance
I have an amp which is designed with a parallel push-pull topology. So 4 power tubes per channel. Circuit is designed for EL34 but i got with Genelex KT77"s (which i run in my SE amp and quite like, although I may dable with 6L6''s if I can find a good deal, damn 8 tubes). Best i can determine with my very limited knowledge is that the OTP's should have an input impedance of 5K (out to 8 ohm speakers). So finally to the actual question, if it's 5K with a simple push pull design - how does having 4 in parallel effect this?
I have an amp which is designed with a parallel push-pull topology. ....
....the OTP's should have an input impedance of 5K
... if it's 5K with a simple push pull design
Why say, If? If the design was done properly for PPP and EL34, it won't be 5K to start with. Why guess about the OPT's primary?
Perhaps, but I read your intention to was to swap the tubes out to 6L6 from EL34. And that the design is PPP and that you have assumed the primary ''should'' be 5K and if it is... Then you ask how a PP at 5K should be calculated for a PPP design... So I'm wondering where the '' should be 5K'' is coming from, if not a guess.
Reactions: Spinspin69
So then why do you say your transformers are 5K? Do you suspect they aren't the correct ones for your PPP amp? The choice for a transformer is somewhat dictated by the class of operation it's forced to run under, the idle current rating, drive limits... before swapping out your EL34, you should have some good operating point parameters established. The cost difference between EL34 and 6L6 just isn't big enough to ''experiment'' with if the possibility of making a wasted purchase is this high. You have biasing and plate voltages to consider.
