Извините, я нигде не могу найти документацию, структурную схему, эти микросхемы. Буду признателен , если дадите ссылку или распиновку микросхемы .Микросхемы очень давно выпущенные etc9668rx и tda7273 .
English please 🙂
Sorry, I can't find the documentation, the block diagram, these chips anywhere. I would be grateful if you give a link or pinout of the chip .Chips released a very long time ago etc9668rx and tda7273 .
Sorry, I can't find documentation, block diagram, these chips anywhere. I would be grateful if you give a link or pinout of the chip. The chips were released a long time ago etc9668rx and tda7273.
I can't find anything at all related to that number. OSAKA isn't a brand seen here.
There is an ST forum:
https://community.st.com/
Also this (I have no idea if it is a reputable site... you have to register... use at your own risk)
https://www.scribd.com/document/358411038/Etc9668-Datasheet-PDF
TDA7273 was mainly used with the motor speed control chip TDA7274 in Personal Cassette Players in the mid-90s, for example DS720 from Philips.
- Member Areas
- Introductions
- Chips released a very long time ago etc9668rx and tda7273.
