Can you define acceptably low? <1% ?Here is how we can use BJT input for ACA Mini.
It is a diamond input. And IRFP240/9240 output.
Distortion is acceptably low.
Is not needed.What if we added capacitors between the bases of the output diamonds?
Actually there is no need for compensation.
The original ACA mini had 0.035% thats like almost the sameTHD 0.037%
Heard it improves voltage swingIs not needed.
I believe we would need more information about why the irf520/9520, maybe i need more bias becuse of the irfp240/9240's higher R-on? Id preferably use irf540/9540 due to their even lower R-on and the fact that i have them.
ive got my jfets in the mail and im wondering if i should try to build it? it seems that it will run hotter at 8W per transistor compared to the original 5W per transistor. it seems that this design depends a lot on the choice of parts.
If I remember right IRF9540PBF and IRF640PBF should be a better pair Rds On 200m and 180mId preferably use irf540/9540 due to their even lower R-on and the fact that i have them.
As with 9540 /540 are typically like many others usually 600m and 180m typically miles about using "matching" N and P channel part suffix
This circuit doesn't really do much better than .1 to .5% distortion
you could basically pull a stereo out of a old Buick and get radio/cd/bluetooth/aux input with 100x the performance lol
just use a 12 to 14 volt switch mode instead. About 10 bucks at a junkyard for a stereo. power supply about 15 to 25
I have an tda7377.If I remember right IRF9540PBF and IRF640PBF should be a better pair Rds On 200m and 180m
Most things nelson pass makes have awfull numbers yet people still like them, also i didnt knew the 640/9540 was a better match.
- ACA mini mosFET/BJT input, thread spun off from here: [https://www.diyaudio.com/community/threads/diy-aca-mini.379037/post-7946869]
