ACA mini mosFET/BJT input, thread spun off from here: [https://www.diyaudio.com/community/threads/diy-aca-mini.379037/post-7946869]
i tried and i got this
Schematic from post # 3,113 draws a surprising amount of power from the puny +/- 12 volt supply rails. It can drive an 8 ohm speaker to ~ 9 watts and remain in Class A the whole time.
Play with the numbers: 47 watts from the +12 supply, and another 47 watts from the -12 supply, gives you 9 watts into the speaker. Surprising!
_
Reactions: chermann
sorting biasing is trivial per se, same as establishing proper Rin (shown as is is ridiculously low), but main thing is stability of all factors in temperature domain
anyhow, if speaking only about building an amp, it's nonsense trying to save 50$ when building an amp worth at least 40 times more
but, if name of the game is learning and trying something new, that's another (shiny) kettle
I got some promising "gibberish", mosfets behave almost like jfets but they need bias voltage which is doable, also i need to get it back to single supply and find better mosfet models, preferably some low power mosfet models.
Hi im trying to built an ACA mini but without the input jfets becuse of an severe case of: "Expensive International Shipping" i cant get them locally, i also believe its a good project and learning exercise.
Im currently on this "promising" schematic:
That seems to just need biasing.
R26 and R30 need to be variable with the FET gate taken from the wiper.
Reactions: lineup
What is your conclusion @Mooly
Should we bypass?
