SMPS Noise and Ground Loop Issues with JLH Amplifier – Need Filter Advice
Hi everyone,
I am building a 4-channel JLH amplifier powered by a 24V Meanwell LRS-150-24 SMPS for a FAST system (2x SB34NRX75-6 woofers and 2x 4-inch full-range speakers). However, I am experiencing high-frequency switching noise and ground loop issues.
While searching for solutions, I came across two different SMPS DC filters on DIYAudio:
  1. ACA Power Supply Filter
  2. PO89ZB Filter
I noticed that these two filters use very different inductor values. One has 2.2µH, while the other uses 180µH. I’m trying to understand why there is such a big difference and which one would be more suitable for my JLH amplifiers.
I also have 10pcs of white and yellow toroidal cores that, as I recall, produce 100µH with 22 turns. Can I use these for an SMPS DC filter? Additionally, I have some 27µH (13x13mm green) inductors.
Would these components be useful for reducing switching noise and ground loop issues? I also have many different capacitors to make pi filters.Any advice, filter schematics, or suggestions would be greatly appreciated!
Thanks in advance!
When using SMPS you have to understand common mode noise. You need a common mode choke between the PS and audio ground. You have to filter the ground side as well as the hot. The line side of the PS needs a common mode choke on hot and neutral (not ground) and a safety ground is not optional because it is also a zero-volt reference.
I think i can find common mode filter in my country(importing become very very expensive and restricted in Turkey) and make filters myself.Is it better to use 4 LC dc filters(one filter for every amp) or only one filter is enough for all? I think bias will be 4A totally.
I found this filter in my storehouse. Can I use it after 24v output ? DCR also seems good. Should I connect earth to case? Sorry I do not know much about filtering and and gnd loops a bit complicated for me.
Amy Alice and PO89ZB and amp camp amp filter does not use common mode filter?
