ACA - help needed
Hi all!
Just finished building this amp and have issues with one channel not working. Once turned on, it just "farts" on the speaker, sounds like a 3 second discgarge noise for the lack of better explanation.
I've removed that channel out of the chassis and tested again isolated, same issue. All components check out measure vise (resistors and caps). Placement is exact as on the working channel. Did the resistance messurements suggested by the manual and here are the results (output connected, input and PSU disconnected):
Q1 -- S = 0, D = 4.96 k, G = 1 k
Q2 -- S=4.96 k, D = 1 k, G = 11.1 k
Q3 -- B = 5.65 k, C = 10.9 k, E = 4.96 k
Q4 -- S = 990, D = 1 k, G = 334 k
Is there any doc that shows how to test for correct voltages? Any help is greatly appreciated!
Thanks!!
Thanks everyone for jumping on this! Somehow I've missed the voltage pic. Here it is:
Q1 -- S = 0.04 V, D = 12.08 V, G = 4.6 V
Q2 -- S = 12.9 V, D = 23.86 V, G = 17.5 V
Q3 -- C = 17.62 V, B = 12.7 V, E = 12.11 V
Q4 -- S = 4.63 V, D = 23.87 V, G = 4.42 V
Everything looks in spec...this is strange...
Picture attached. Curently only power input is connected. When testing, IN + and - goes to input signal cable + and -, OUT + goes to + lead on speaker and ground, - goes to negative lead on speaker.
Hope this helps!! Thanks!
@tjw59 there is no input connected.
To summarize:
  • board is out of the chassis
  • all caps and resistors have been checked individually
  • no shorts on signal input or output
  • resistance check, input disconnected, output connected:
  1. Q1 -- S = 0, D = 4.96 k, G = 1 k
  2. Q2 -- S = 4.96 k, D = 1 k, G = 11.1 k
  3. Q3 -- B = 5.65 k, C = 10.9 k, E = 4.96 k
  4. Q4 -- S = 990, D = 1 k, G = 334 k
  • voltage check, power in connected, signal in and out disconnected:
  1. Q1 -- S = 0.04 V, D = 12.08 V, G = 4.6 V
  2. Q2 -- S = 12.9 V, D = 23.86 V, G = 17.5 V
  3. Q3 -- C = 17.62 V, B = 12.7 V, E = 12.11 V
  4. Q4 -- S = 4.63 V, D = 23.87 V, G = 4.42 V
What am I missing? Should I ask for a refund or new transistors for the board?
Your voltages and resistances look reasonable so I do not think there are any problems with the transistors.
Check your solder joints at C1 and R14. If uncertain, reflow them.
Also with no speaker connected, set you meter to DCV and connect it to speaker out, and turn on the power. Is there constant DC voltage, or does the DC voltage appear and quickly go to zero?
In your picture the white lead is on the ground terminal and the black lead is on the positive terminal. If you are applying your input to the white wire then it is going to ground.
