Yes.@lineup
If I wanted to add a volume control to the circuit, can the 100K resistor be replaced with a 100K pot ?
That would be perfect.
The minor drawback is that TLV4111 (or TLV4110) is only in SOIC-8.
That is a small IC.
As I said this fits 8, 16, 32, 60, 100, 150 and 300 headphones.
For 600 Ohm there are better amplifiers.
Slew rate of this op amps is awfull at 1.5V/us even the rc4558 has better slew rate at 3V/us.This opamp can work +/-2V. Which can be powered of 4x1.5V batteries.
And delivers into impedances 8-300 Ohms.
The performance is very good.
Also what is the point of R5?
@No ideas
I haven't considered the slewrate.
But I think it is good enough for this application.
The major benefit of TLV4111 is the low voltage +/-2V is no problem.
Also it has Rail to Rail output.
And high currents is no problem.
Given those conditions it has a good output into those headphones.
the opa165x works from +/-2.2V and up and has excellent specs, it also seems that i should have an easier time finding it.
oh thats why. only issue i have is that its quite expensive becuse i would need to get it from mouser/digikey
More than enough given the low voltage swing.Slew rate of this op amps is awfull at 1.5V/us even the rc4558 has better slew rate at 3V/us.
If the maximum voltage swing is 2 volts peak then the slew rate needed for even 50kHz output is 2pi*f*vpeak which is 0.63v/us
There are also DIP8 versions:The minor drawback is that TLV4111 (or TLV4110) is only in SOIC-8.
That is a small IC.
TLV4110IP
https://www.reichelt.de/de/de/shop/produkt/operationsverstaerker_1-fach_dip-8-188998
Aliexpress is the last place i trusthttps://pt.aliexpress.com/item/1005005137036075.html
https://www.aliexpress.com/item/1005007229582416.html?spm=a2g0o.productlist.main.5.23466b36T1CcA6&algo_pvid=8dda724b-ced6-4e13-ad0f-4f87c65e0b25&algo_exp_id=8dda724b-ced6-4e13-ad0f-4f87c65e0b25-2&pdp_ext_f={"order":"-1","eval":"1"}&pdp_npi=4@dis!RON!14.70!14.70!!!3.03!3.03!@2103919917402175497195231eadc3!12000039887510772!sea!RO!790126454!X&curPageLogUid=kLHAmWQWTki3&utparam-url=scene:search|query_from:
ORIGINAL!!! 🙂🙂🙂🙂🙂🙂
TLV4110 has a shutdown pin.
TLV4111 has not.
TLV411X has very hgh current output. 300mA according to datasheet!!
TLV4111 has not.
- Headphone Systems
- 4x1.5V Batteries Headphone Amp
