Best Power supply for class A transistor power amp?
I would consider the PSRR of the amp and whether a stabilised or low ripple supply would be a benefit. Maybe separate stabilised supplies for the front end and unregulated for the outputs. It is all amp specific really.
Reactions: lineup
Start here and leave room for more caps.
Hello Dyers, I`m looking for the best possible schematics for the above, I'm going to build a power amp in class A and I want to know, which PSU is considered the best, and why ? Thanks !
Which amp you gone build? What will be the bias current? What will be max power? What is the psrr of the amp? What do you main with best? I know a lot of questions. But there are a lot of solutions.
Properly done, linear regulation has to go beyond the cursory requirements of the amplifier ratings. The regulator should be capable of ten times the current of the continuous output of the amplifier channel.The regulator should be preceded and followed by large capacitances with values comparable to those needed for unregulated circuits. The transformer size still needs to be as big as that used in an unregulated circuit. Approached in this manner, linear active regulation delivers the goods.
Have you read Nelson's thoughts on this from his Power Supply paper?
amp is mine invention nothing fancy 2 pp with 2SC5200/2SA1943 , power is not a factor here , aiming for a cleaner signal so i really do not care about , desired voltages to be powered around +35 to -35 V , BEST for me is less distortion and true bass 😉
Reactions: lineup
