Which box for JBL 2042HPL
Hello everyone, question for experts, I have a couple of these speakers JBL 2042hpl, 18 inch
Please tell me which box to calculate for these speakers to listen to at home.
Thank you very much to those who responded
Best regards Dmitry
Needed for 20hz -(6-9)db 🙂
Hmm, dropping a full octave means a doubling of Vas tuned to 20 Hz, so averaged specs = 749.78 L/F-9 db, right up there with some of Altec's max flat alignments. :yikes:
Vent = 10" pipe x 30.5 cm for low enough vent mach, though best to cut it long if wanting a most accurate tuning.
HR calcs a 150 W max/20 Hz assuming a 9 mm Xmax.
Как вы получили эти измерения? @@Левтерофф
hello, For this measurement you need a special device with resistors, An impedance measurement is made, after which a second measurement is made with additional weight; it can be from 50 to 100 g
  • Thank You
Reactions: SamAnytime
Might take GMs or some of the pros skills to get a nice flat response but one of the design wizard default TL settings with a tapered line attached. Can tweak more in the loudspeaker wizard. Still is a large box. MJK 2006 alignment triples that volume but response looks nice. .Screenshot 2024-12-13 at 10.41.03 pm.png
Hello everyone, having these speakers
Tell me which box can be built for them, do I prefer a transmission line or a Back Horn. I have my own carpentry workshop and have CNC machines, Therefore, I can implement a complex project very easily. Thanks in advance to everyone who can help
Best regards Dmitry
