Ground Loop Breaker, but what's right and what's wrong.
You could design it to be class II (with double or reinforced insulation and no protective earth), or try to design it with balanced or quasi-balanced connections in the spirit of AES-48, or use protective earth on only one piece of equipment so it doesn't cause ground loops, or try to minimize the loop areas formed by the signal ground wiring and protective earth wiring.
Getting back to the moving coil cartridges from post #1: the cartridge is usually insulated from the rest of the turntable, so it should be possible to hook it up to an earthed amplifier without causing ground loops.
Thanks Marcel, I will think about this. You are right, I think MC cartridge are usually insulated: Not sure if this is true also for MM. But the cartridge provides differential signal per design. Maybe I try to use this as a benefit, good proposal.
The best you can do Is do 2.class with "silent" earth to keep safety and avoid questionable rdc.
If you want maximum safety, use transformer with earthed shield primary, earthed chassis. All mains double insulated, and than connect amps gnd with earth at audio input connectors. No RDC and minimum earth-loop involved. If I understand this is phono, than connect earth and gnd at preamp output connectors, not input.
Reactions: Mr.Knackwurst
By the way, common sense tells me that this is not safe:
(Fuse and mains switch not drawn for simplicity.)
Assuming the "poorly insulated transformer" has good enough insulation for class I equipment, it would be safe if there were a connection from signal ground to protective earth or if there were no cinch or other connectors to touch. As drawn, touching the cinch connectors that are mounted insulated from the metal enclosure as well as the metal enclosure will give you quite a shock when the transformer insulation fails.
I read about it. Do you know why it's necessary to connect PE at the output GND of the amplifier? I guess it's related to the insulated cartridge at the input and the earthed amplifier at the output, isn't it?
Reactions: Wiliks
That's my understanding and drives me a little crazy. Maybe basic insulation (your poorly insulation) is only allowed for a device that provides no interface to the outside? If you have an interface, you may need a double insulated transformer. Or will reinforced be fine as well? More and more questions, I'm sorry about that! 🙂
Interesting link, sounds like Reinforced Insulation is necessary between primary and secondary and Basis Insulation between primary and earth. That should be valid in mostly all small audio devices and makes sense for me and matches to the things discussed above. This matches to the chargers I mentioned as well.
https://www.xppower.com/storage/documents/technical-articles/High-Pot_Testing.pdf
They specify that if the secondary voltage is below a maximum voltage, there are no test requirements related to the seconary. This let me assume, that if somebody like to have a GLB, it's important to know that your transformer is at least Reinforced Insulated. But be aware, that for a retrofit it may be difficult to know the safety concept the manufacturer chooses and know that they do everything right. If it's legal in your country is another topic to check, but from a safety aspect, know all details of the safety concept and the transformer before doing something critical.
I'm still not sure about the Double Insulation. When do we need this?
what is your issue?
why do you think a GLB will help with MC phono noise?
I'm afraid of the higher gain. My MMs are really silent, no hum and no issue. The new design is a puristic JFET design with higher MC gain. I try to be careful, consider the design recommendations I know, and I very often read about a GLB recommendation but the legal questions. Therefore I ask to get a better understanding.
