Transformerless very low ripple <10 uV PS +-18 V 50 mA for top quality phono preamp
Use of the LC filter indeed makes more sense than cheap LDOs in this case. Although there are modern LDOs with higher bandwidth, like tps7a47, they still do not provide enough PSRR at high voltage (15-20V) output in the DC-DC operating frequency range.
But somehow I do not feel comfortable with proposed LC values, 2.2mH and 31 Ohm is too much. I'd rather use 2.2uH/220uF + some small MLCC.
There are many possible choices for component values in LCR filters optimized for the correct quality factor "Q" , @eclipsevl . For example,
PO89ZB on these Forums uses (2.2 microHenrys + 0.04 Ohms + 470 microFarads)
AmyAlice on these Forums uses (10 microHenrys + 0.10 Ohms + 470 microFarads + 1.0 microFarad RF Feedthrough capacitor, P/N YFF31HC2A105MT000N by TDK)
One way to explore the performance characteristics of the filter linked in post #1 above, it to examine its behavior in circuit simulation. Perhaps using LTSPICE or QSPICE
Reactions: Nick Sukhov
I use a Microcap 12 simulator, see attached results
Just run a transient simulation of the phono amp with such filter and you'll see
To measure the PSRR, you must apply the "input" signal not to the phono preamplifier input (there is no 400 kHz there), but in series with the +18 power source, in addition, to the left of the resistor R23, you must include a grounded blocking capacitor of 0.2 uF, as is in my filter circuit and phono preamp PCB.
This is not a PSRR simulation.
Yes, I have it.
The simulation shows that due to IR drop on R23, there will be ripple on the amplifier power rails. The frequency of input signal at the waveforms above is 1kHz.
Perhaps you assume that current consumption of the phono stage is constant regardless of the input signal but it is not. So power rails effectively modulated by the input signal with such high impedance power source.
That was my main point, one should not only consider AC performance of the filter but also overall output impedance of the power supply.
The simulation shows that due to IR drop on R23 (in my simulation it is R35) THD even decreases - see attached data
Reactions: Drone R2D2
