Hi . I have this transformer and pcb board is broken . I cant use switch to put it on 220v input . I will be thankful if help me how to run it directly . It has 6 pin . I need to know where to connect N An L also if i need to bridge between pins to put it on 220v mod . Thanks
It works . Thank you my friend .
I have a sharp md-xv300 . Its transformer is dead . I replaced with a Panasonic transformer but its 110v i need to use converter . I wanted to replace with a 220v transformer . I have two 220v . First one has same voltages like Panasonic that i replaced but as soon as i put in in power one diode and fuse burns . Pcb is for original sharp is it possible its diodes cannot handle 12v from 220 transformer because it has more amp ? Is there any solution because ac voltages are same
Hi again . I solved the problem for burning fuse and diodes . There was a bridge between 2 ground of hi voltage and low voltage of output . Cut it and know it works . I have another problem know . Screen of my system powers on a single ac cable i don't know which wire is its pair and don't have schematics . When i connect it to opessite 12v ac it turns on but it make noise . I disconnect it and sound is clear . Dont have any other options for screen i don't know if you can help me about this problem its kind of complicated . But if you help me run little transformer on those schematic maybe i can get another source of power for screen . I mean 220v inputs of small transformer. Sorry about my. English and thank you . You help me back a system that i loved . I wish you bestIf you've got the transformer from the 1st schematics, you need to jumper pins 5 to 3, resolder the fuse to the tap of the upper primary half, and connect mains to pins 6 and 2.
Best regards!
Hi . Yes my friend . As the pcb is broken i cant find out second transformer (little one lower right corner ) how works on 220v . thanks to you Big transformer works greatly and i ran my amp but i have noise problems when i get power for filament maybe with additional power source i could fix it . Just need to find out witch pins are for 220 or like last one i need to make a bridge . 🙏💐
Exactly i mean second transformer . Little one lower right . Sorry my English isnt too good . About screen i mean vfd lamp that shows equaliser and volume......when i connect it lots of noises makes . If i couldn't solve that i put a switch on vfd screen after playing music i will turn it off manually . Also volume and key working when vfd is offHmm. It's getting really difficult now, as I don't know what you mean by screen, and I need to guess what's the 12 V transformer. Is it the 2nd one shown in the lower right cormers of your schematics?
Best regards!
Hmm, without any schematics it appears to be difficult, for not to say impossible to solve your issue.
Best regards!
Best regards!
- Power Supplies
- Transformer 220v input
