Wandel & Goltermann analyzer, is it worth refurbishing?
Joined 2024
I'm not sure was it Santa or Satan who brought me this for Xmass??
It was sitting in humid and cold shed for years, but apart of few unimportant knobs and covers, it is complete. I left it in worm and dry to condition for some weeks before attempting to power up.
Half a century ago this was the top that money (a lot of it) could buy, but question is is this worth rebuilding today when REW and soundcards do all the job?
Reactions: gerrittube
I have one in mint condition, and it’s working great. I don’t have a purpose for SPMX-110 that I have as well, but I’m not involved in radio transmissions. Do you know how to use the bottom unit?
However I prefer a good soundcard with decent software.
Regards, Gerrit
Reactions: Drbulj
Two questions spring to mind:
i) Do you have a service manual?
ii) How much spare time do you have?
If the answers are 'yes' and 'lots', then go for it (I find pointless refurbishment of obsolete electronics a lot of fun, although I don't have time to restore more than about one item a year).
It isn't going to tell you anything that a decent soundcard + REW will, but you won't have to wait for it to boot, nor will you have to worry about scaling everything so that the results bear relation to the real world. I have numerous AAs such as UPV, AP, Prism etc, but I still use the Lindos LA100 daily as it's so convenient. The W+G would be a little like the LA100 -if in working condition. It's nice to have an instrument that shows distortion and FR within 10 seconds of turning it on: "is this working?"...ten seconds later, "yes, it is. I can do detailed measurements later, but it looks ok for the minute". Hardware is nice to have. The W+G will impress visitors. It will have better geek value than a soundcard + laptop.
Hi, thanks for very good answer..... I have similar feeling about it.
I do not have time for it really, it will take weeks to get it in good condition.....
First I will see if it works as is after climate conditioning and bit of cleaning , if it works I will keep it, if not I'm very tempted to cannibalize those 1% and 0.5% capacitors that go up to 150nF, these are unobtainable today and fantastic for filters of any sort....
You will regret cannibalising this for parts. W+G stuff is really nicely made and it's a piece from a bygone era. If you don't have time to restore it, I would suggest selling it on Ebay or here. Hopefully someone will fix it up. Check that it doesn't have Frako electrolytic caps. A lot of German gear from this era used them (unlike some Japanese caps that last decades, the Frako are a rotten part) and they are nearly always shot. They can pass DC and cause damage. It could be as simple as changing a few caps.
Reactions: Drbulj and Miller-8
I recapped a 1978 power Amp last yr, simply because I had new surplus caps and i have a Hakko gun (it was on bench for other repair and apart). Every Nippon Chemicon cap was in-tolerance WRT ESR and value. Had the amp had Frako it would be a different story...
Reactions: Drbulj
Im still using some Sprague screw terminal "computer grade" lytics from same year (i think its same) , these are spot on ... But there are lytics and lytics, better to replace to avoid smoke.
Reactions: thermionic
