Electrostatic Speaker Model
I'm looking for a model of a planar electrostatic speaker represented by physical components, similar to the speaker model presented in this Stereophile magazine article. Although an electrostatic speaker is often described as acting like a capacitor it is also usually quoted as having a nominal impedance, usually 4 ohms. Since a capacitor's reactance varies continuously with frequency it would not seem to have a "nominal impedance" so I'm thinking that the speaker model must be more complex than just a simple capacitor. Does anyone have a model that is a good representation of an electrostatic speaker?
According to Walker's equation, for frequencies above the fundamental resonance and below the frequency where diaphragm mass comes into play, a flat-panel electrostatic loudspeaker must be driven with a frequency-independent current to get a flat response in the far field.
Therefore, the step-up transformer should not be connected straight to the stators. In fact, the stators should be segmented and driven via some sort of crossover filter. In the ESL 63, a damped artificial transmission line is used for that.
All in all, it depends a lot on the electrostatic loudspeaker design. I know there is a thread about modelling the ESL 63 somewhere.
Edit: this is it: https://www.diyaudio.com/community/threads/quad-63-and-later-delay-line-inductors.338927/ That is, it diverged into a discussion about ESL 63 modelling.
  • Thank You
Reactions: GM
  • Thank You
Reactions: GM
The Quad ESL model looks to be realistic and is comparable in form to the Kantor/Atkinson model presented in the Stereophile magazine article I cited earlier. I added node labels to the LTspice .asc file and then created a subcircuit from that (both attached). I then tried this speaker model in place of a load resistor in several of my power amplifier simulations, and it does give reasonable looking results.
Thanks to all. I think I have something that I can work with.
  • Thank You
Reactions: rayma and GM
Member Hans Polak has developed a detailed model for the QUAD ESL 63, including the step-up transformer and the physical parts of the transmission lines. I have done measurements on the speaker and can confirm that Hans' model is very accurate.
Note that the QUAD is much different from other ESLs; for instance, the Martin Logans are much more like a capacitor.
So there's not one model that fits them all.
Jan
Here's Hans' detailed model, which includes the xformer, diaphragm resonance, proxinmity effect at 1m, baffle effect and stator transparency. Did I say detailed?
But you can simplify it a lot - my measurements with the Bode100 analyzer show predominantly resistive around 400k between 500Hz and 12k.
Jan
I have no clue about SPICE. Can someone show a circuit diagram?
Also, it might be nice to apply these models to electrostatic headphones. I measured my Stax 9k here:
For clarity, what I wrote in post #2 does not apply to headphones. Electrostatic headphones are meant for listening in the near field, so they have to be driven by a frequency-independent voltage rather than current (when certain assumptions are met).
