Output capacitorless Mofo
If you for some reason want to dump the output cap, this is an idea of how to deal with it and still keep it pure SE. As I have a pair of 193U and matched IRFP240s, they are used in the sketch. It will probably be a hazzle to adjust bias for both terminals to zero over the sources. A circuit breaker that monitors any DC over the speaker terminals will surely be needed.
Off course it could be adopted to the 2024 Zenductor 2.
Agree, if the fets where perfectly matched no trim would be needed. With matched fets they will probably follow each other with temperature, once their Iq is alike, but IRL some kind of trim will be needed to balance the pair.
Silly idea (I won't patent it) but if you now would make a normal single ended amp but put one end of the speaker to the center of the power supply? The amplifier using the complete voltage over both windings.
It would smoke the speaker at the slightest provocation but if you want to live dagerously, why not?
point is - use common voltage reference for both mosfets, and fiddle with time constant for second mosfet, to have them so-so same in biasing speed, thus keeping DC Offset as low is possible, in time domain
practically - one voltage source (say 9V), separate trimpots for each mosfet
in the end, you can skip any additional time constant for second mosfet
sorta same as in PP tube amps, each halve having own biasing trimpot
  • Thank You
Reactions: revintage
Maybe fiddle with C2 and C4 in my planned midbass amp?
C2&1kohm and C4&200ohms both give 1s.
Input driver needs lowish Zload to get desired H2.
Eventually an 1:2 input transformer could be used instead of driver stage together with a high Zin bias network, as speaker has 100dB sensitivity.
The previous attempts where not so funny due to high Zout and power consumption.
With the help of a standard 3.3V SMPS it might work better. 193U has 1.7ohm DCR and this means 1.94A. Hopefully also in IRL 🙄 . A protection relay will come in handy, though.
