Running BMS 5530 / 4550 down to 600 Hz
Has anyone tried running one of these drivers down to 600 Hz in an appropriately sized horn with a steep electronic filter?
BMS themselves actually rate it from 500-20 000 Hz.
Seems to handle even 110 db at 600 Hz on the Dayton H812 so I can't imagine it being an issue in a domestic setting:
https://www.justdiyit.com/grand-comparatif-de-compressions-1-pouce/5/
In fact, all of the ones in the above test seems to be fine (with the odd exception of the ND350)
Yes. Small diaphragm CDs can go to 600 and may produce high levels free of distortion in a domestic setting.
You'll still want to pay attention to where the limits are. Cutting with a steep slope helps up to a point. You won't see a benefit from ultra steep slopes and you'll only run into group delay issues and give away your blending region.
LR24 @ 600hz and 4 bands of parametric eq for this response. Listening test with one horn on top of 2x15's.
This combo did much better than I expected! I pushed it to shouting levels at the listening position 4m away.
These can definitely be used down to 600hz in typical domestic settings.
Impressive little driver. I will use these in PA tops crossed at 1khz.
Reactions: Defo and AllenB
Thanks for the measurements! Quite the rise in distortion below 900 Hz. Strange though, since the same behaviour isn't observed in the test on the Dayton H812 horn in post 1. Which also loads down to ~600 Hz same as the Ciare.
Reactions: Dkalsi
I think we're seeing the advantage of the exponential flare in the Dayton. It will naturally load the low end better while narrowing high frequency dispersion. It took a lot of eq to push that low in the Ciare.
The Faital HF1440 or JBL D2 are probably the best bet for clean low end and top octave extension from a single diaphragm on a constant directivity device.
That being said...I was surprised to prefer a 600hz crossover vs. 1khz. I was expecting the rise in distortion to really present itself at higher listening levels.
Reactions: Defo and mayhem13
