Wharfdale MODEL 3014 speakers, are they any good?
I'm able to get a pair of Wharfdale Model 3014 woofers for 60 dollars.
Is there any problem with putting them in a bass reflex cabinet? Is there any plots available for these?
The Wharfedale 3014 drivers are intended for installation in a sealed enclosure like the 45 litre one of the Wharfedale Dovedale 3.
Here are the driver's specifications:
Heavy duty paper cone with rubber roll surround
High stability rear suspension
Outer chassis diameter 315mm
Inner cone + surround diameter 305mm
Mounting hole circle diameter 320mm
Nominal impedance 6Ω
Large ceramic magnet, flux density 135,000 maxwell
System power handling 50W DIN
Driver free air resonance 25Hz
Response is only 3dB down at 45Hz in a 45 litre sealed cabinet
Upper crossover frequency 600 - 1,500Hz
Note the very low free air resonance frequency.
The 3014 was also part of the Wharfedale Unit 5 kit whose instructions state a bass resonance frequency of approximately 17 Hz - definitely sealed box territory.
A sealed enclosure of 4 cu ft would be too large. Wharfedale's stated maximum volume for the 3014 was around 2 cu ft.
You could always partition off the interior of your 4 cu ft enclosure to provide a sealed 2 cu ft volume for the 3014.
Reactions: myfirstamplifier
