Well. Here is the inside of a 1969 Soviet era Turntable. It's a doozy😜
Apart from the unidentifiable cylinder that looks like it's been at the bottom of the ocean since 1969, the tone arm that seems to suddenly have a ton of tracking force, there is an unidentifiable contact switch hanging loose.
It's a brick.
Oh the turntable turns......kind of.
But it looks soooooo cool.
I could make this a quiz?
It's a brick.
It's an idler drive turntable from a Rigonda Stereogram:
https://www.radiomuseum.org/r/radiotehni_rigonda_symphony.html
https://www.vinylengine.com/turntable_forum/viewtopic.php?f=18&t=88194
These parts have originally green surface - they are wire wound power resistors.Apart from the unidentifiable cylinder that looks like it's been at the bottom of the ocean since 1969
What exactly is your question - if any?
Thanks. My ignorance.Just for interest, the logo on the turntable label stands for "Rigas ElektroMechaniska Rupnica".
Riga is in the Republic of Latvia, one of the three Baltic states.
I suppose my questions are:
The resistor in question. Can it be replaced and with what?
What is the contact switch and where did it come from?
Am I crazy to try and restore?
Functionality wise I would not play any records on devices like these.Am I crazy to try and restore?
As a home decoration piece that resistor probably does not matter.
Yeah I wasn't expecting a lot but was thinking more in lines of an old player playing old vinyl and 78s, singles etc. maybe a prop dept could use it.
I would recommend using only records that you are ready to discard for this activity 🙂...thinking more in lines of an old player playing old vinyl and 78s, singles etc.
- Analogue Source
- RemR P93 1969 Lithuanian Made Turntable
