Kenwood Receiver KR4140 Bulbs
Hi
Im looking for a UK supplier who can provide me with replacement facia bulbs (8v 03a) I need three which are the clear fuse looking type (28mm x 6mm).
I also need a small bulb I think they are called wheatear in the US? no idea of spec but its the light which illuminates the STEREO text for FM signal, See Pic.
Hope someone knows of a supplier.
Ta
I was able to find suitable replacement wedge-base bulbs/lamps for an old Pioneer receiver at the auto parts store. 194 or 168 bulbs were drop in replacements. I used the 194's rated at 2 candle output. The 168's are rated at 3 candles.
Approx 9.5mm x 25mm
Hope this helps
Reactions: stubbs04
Okay so a related issue, kindoff. A rogue white wire (one of two) (see here circled in Black next to my digit) that connects to the small lamp that sits atop the 'FM wand' that moves left to right!!
I cant figure out where its came from, it must have just snapped when I've been prying around.
it must go to one lug on the encircled black plate?
Oddly the lamp which is the FM indicator (circled in red) now lights up if I touch the rogue wire to the red circled lug. (I know that was a dodgy thing to do and honestly I'm not going to try anything else untiI I get some pretty sound advice on where it needs to be soldered to.
This obviously is coming from someone that knows minimal electrics.
Sorted. Turned out that if you remove the small lamps it breaks the circuit even if they are blown although one wasn't ). The snapped wire leading to the tuner wand was joined to one of the other lamp terminals that lit the panel and these are in a circuit line.
I've probably just made up a new set of electrical terminologies there. Apologies to the electrical engineers on here. 😜
Reactions: seventenths
Some Japanese sets used the fascia lamps as a fuse, so for somebody unfamiliar, it can cause head scratching to people trying to find the fault.
On an old set with obsolete hard to find parts, extreme caution is best.
I would get the manual, check with a meter, and then try repairs.
And my first preference is LED or automotive lamps, the axial 'fuse' type bulbs were common as interior lamps in cars, a 5-10 Rupee item in retail here (5-10p UK).
