I2S connection help
I own an old dac with an 13W3 I2S input, I tried to search online to find what pins are used in the connector so I could make a wire for it to no avail.
is there a way to know what pins are used so I could make a cable? maybe I could look at the circuit board?
the dac I own is the muse model two plus. (cs8412->df1700->pcm63)
the cs8412's job is to convert the s/pdif inputs to I2S for the df1700, which then converts the I2S to an output that the pcm63 can read.
by connecting the I2S input I will be able to bypass the input receiver (cs8412), and will be connected directly into the digital filter (df1700). which is why I want to do so.
maybe I will even change the df1700 in favor of a pmd100 later, but first I got to figure out what to do with the I2S input.
Reactions: EitanDainn
The use of the I2S HDMI connector is not standardized, so different companies may use different pinouts.
However, the main difference is the polarity of the signals.
Here are some examples:
that much I know, the muse model two uses a 13w3 connection and not hdmi. I just need to figure out the pin so I could make a hdmi->12w3 cable for my dac and whatever DDC I will choose.
my question is what are those +/- connections, the df1700 doesn't have those, does this mean I won't be able to connect modern DDC'S with such +/- to my dac?
a few of the pins from the 13w3 seem to be connected to the Motorola mc7402p sixth pin via a wire
