Building a radio receiver: Need help on the audio stages
Howdy! I have a project going on right now, where I am building a radio receiver from old tubes I have(type 76s, type 41s, etc), and other components I find around. I know how to make capacitors, rectifiers, and a lot of other components, but the circuit itself is one issue. The detector is another, because I need a datasheet of the 76 with grid current specs, since I need to bias the grid to about -15 volts for it to work as a detector, and I can't use a battery for that. Any tips?
To do anything serious with early amps or radio find copies of the RCA Tube Manuals RC12 & RC14.
You could try Amazon, they started out in the book business.
Better still Alibris, https://www.alibris.com/
I found pristine copies of many technical books. Including Terman.
I've built many amps & receivers. These books were a great reference.
The photos are from a talk I gave at the local antique radio club a while back.
  • 76 RCA.pdf
    76 RCA.pdf
