TWQT / Hornresp help needed
Hello! 😃
I have a question about (folded) Voigt pipe speakers. (TQWT)
I’m thinking of making such a folded Voigt pipe speaker and I have seen some YT video’s of how a voigt pipe speaker(cabinet) works, but not in great detail.
It doesn't look/seems to look very difficult yet.
The difficulties for now are ā€˜putting everything into Hornresp.
I have two questions about that.
1: I have a drawing of the cabinet I want to base my speaker cabinet on, and there is a drawing (not to scale) I made with some S-L values in Hornresp.
But it’s a bit unclear to me what surface area and what length exactly what I have to fill in to Hornresp? I see some differences in what I have found on the internet.
2: I want to places full range driver and I want to know/see the full frequency response of the speaker when it’s finished.
Can I simulate that in Hornresp? If yes: How?
Hope someone here can help me a little further with this project.
Thanks in advance! šŸ™šŸ»
No, you cannot include the driver's specific frequency response into a hornresp simulation.
But you can simulate the low frequency range of your speaker very well, based on TS-parameters and the simplified enclosure model.
Baffle diffraction impact, driver beaming and breakup, eventual other driver-inherent resonance effects cannot be simulated/included.
Reactions: planet10
@Niek you can use VItuixcad for that, but of course the result depends on the data you feed it with. You could even export the low frequency response from hornresp and merge it in vituixcad to your measured or datasheet-response.
Reactions: Niek
If that doesn't clear things up, let us know what you have and where you're stuck.
I still don’t know in how many segments the TQWT has? I still don’t know exactly where the L-S values stands for šŸ¤·šŸ»ā€ā™‚ļø
Same with the values: Con, L12, L23, L45
I don’t think it’s difficult to play with the sliders, but I still can’t find how to fill in the values for a tqwt.
Does anyone have an idea how this TQWT type to setup in HR?
How about the ā€˜port’ in the bottom left?
I have a S1 at the bottom and it’s also a port. Is this possible?
Thank you šŸ™šŸ»
Thank you šŸ™šŸ»
Apparently you have not yet seen the PM from Sunday? We will help, but very seldom will we do it for you w/o seeing you try first (it's DIYaudio).
Reactions: GM
Hello again!
A question about how accurate HornResp is.
Here i have an example I made in HR. I think the response will be quite accurate below 150Hz. But how accurate is it between 200-1000Hz. What are the experiences here in that regard?
The question is about the red line.
Cabinet: TQWT. 4 sections.
Driver location: Between section 2-3
Damping is also placed virtually.
