Folded TQWT for SB Acoustics 6½″ SATORI MR16P-4 / Paper
Hi there, could somebody help with checking this box design I did for the above Satori driver using the Boxplan-TQWT spreadsheet?
I tried to export this design into Hornresp but found it too tricky to extract some meaningful information.
I'm not looking for suggestions for a different type speaker design, I only want to make sure this works reasonably well.
I like this particular type of TQWT fold, where the tapered end is folded 'behind' the driver towards the back rather than the other way round.
One question I've had: this design appears to have a distinctive 'port (S5), whereas I've seen other designs where this is simply an opening. Anyone care to explain why?
Cheers
  • boxplan-tqwt_SATORI_v2.xlsm
  • 6½in-SATORI-MR16P-4.pdf
How very strange. Only this morning, I was reading about an acoustic patent application in volume 37, issue 12, October 2024 of Voice Coil magazine that is quite similar to this design! Wanting to know more, I started to search here at DIY, and this thread is the first that I encounter. In the description the design was actually for a transmission line that also makes use of a port in the lower octave. I see that what you have looks to be a tapped horn design with a port of sorts? I find either of these ideas intriguing though seemingly experimental, at least to me.
Intrigued as I am about all of this, I can only stand aside, waiting for someone to comment. So glad that you have brought this forward.
As far as type is concerned, all perfectly standard & been in use for decades I'm afraid. How in the name of sanity some of these patents get through I don't know, since to put it mildly, 'prior art' is in effect. 😉 They're normally called ML-horns, TQWTs, Voigt horns, single-tapped horns etc. -folded, as shown above, to fit into a regular rectilinear box form factor, which in most cases makes them fairly redundant since a simple MLTL will usually do the job as well or better, with less complexity. YMMV as always of course.
Reactions: perceval and GM
Thanks. Surprising about the patent application.
I'm aware this is an old hat, and that a simple MLTL might be doing the job just as well.
However, I was just looking for constructive feedback on my particular design, not suggestions on what type box might work better.
