Horn loading of cones and domes drivers (i.e. not compression)
It is actually dead easy. Mids as close to the HF driver as possible and bass as it fits, it does not matter much if further out. 3" drivers can get easily over 1000 Hz crossover even with center placed port. Build a cheap prototype and measure it. I used chipboard. The more difficult part is the crossover - easier to do with DSP, passive is doable, but difficult, at least for myself.
  • Thank You
Reactions: ginetto61
Thanks a lot In the meantime i found the graph that shocked me
i cannot find the source
I am astonished by the effect of horn loading
i feel like i want to horn load my car engine
Well, with a ~325 Hz Fs/0.3 Qt, then its upper mass corner (Fhm) is ~2*325/0.3 = ~ Hz just as measured; a ln(2167/325)/ln(2) = ~2.737 octave spread.
Hi ! Thank you very much for the very valuable formula that I don't understand
You mean that is possible to calculate the usable range from TS parameters?
I can measure them with the beautiful Dats v3 one of my most loved toys these days
The horn design will be quite critical I guess
But nobody said the the path to pleasure is easy
This was one of the threads I was thinking of..
pelanj👍
  • Thank You
Thanks a lot Until now i knew only the rule of low cut a driver at around 2xfs Hz
finally i can measure the fs of a driver Next step will be to study REW well I understand is a very popular SW
I had some issues with my sound card I will ask for a sound card surely supported by the SW
Reactions: head_unit
It is Multiway etc. DSP is your friend.
I just copied what was out there.
Worked brilliantly.
So well my 5 way individual horns (Le Cléach HF / Tractrix MF / Exponential LF) system was replaced by one MEH🙂
There are plans for smaller 2 way versions and build blogs here on DIYaudio of course.
Down to 200Hz with perhaps a 6" MF would be doable.
8" drivers with rear enclosure can see you down to 70 - 80Hz.
Then you just need a sub.
This is from the ATH4 thread.
3d printed!👍
I'm in awe of what they are doing.
I'm old school wood so far.
You could have a cone HF and 1 or 2 8" LFs.
Don't be thinking these are only for PA. They sound amazing nearfield and hifi detail / vol levels. But with the single point sound source and if you go phase coherent on the XOs its another level.
Is the bottom photo the rear of the horn pictured above it?
