can DACs sound different if they both measure well?
can DACs sound different of they both measure well?
  • Yes, I know I can hear the difference
    Votes: 69 45.7%
  • I think I can hear differences sometimes
    Votes: 26 17.2%
  • Not sure
    Votes: 18 11.9%
  • No, they will sound the same
    Votes: 38 25.2%
  • Total voters
    151
Just as an example of lousy close-in phase noise in chifi dac here is >120dB SINAD SMSL DO300EX with AK4499 (in green) compared to Diyinhk AK4490 (in blue), (courtesy of @gaycoh).
What actually is "phase noise"? Loudspeakers produce large phase shifts and the music playing in your room is bouncing off walls etc. Is "phase noise" from a DAC going to be significant in any way here? Turning your head a few degrees is going to cause phase changes.
Have you measured the phase accuracy of many DACs?
What do you mean by that question? How are you defining "phase accuracy?"
From the question, it sounds like you have no understanding of phase noise in a dac?
Anyway its like this: Every dac needs a voltage reference and a time reference. Both are analog signals. Noise in the time reference as viewed in the time domain is called jitter. Viewed in the frequency domain its called phase noise. Close-in phase noise is a special part of the phase noise spectrum that is important in fields such as audio and in radar.
No. That show's that the psu filters in the Topping DAC are well engineered. If he measured a stock Topping DAC, then took out the psu and decoupling and coupling caps, measured their parasitics and then changed them for other caps with the same capacitance but different parasitics and then measured the DAC again and the measurement results were exactly the same, then you could assume that the capacitors do not affect sound.
But the cheaper DACs measure pretty much just as good distortion wise so I dont think the power supply is an issue in any of them. Do you?
Close-in phase noise is essentially the same as random wow and flutter. The clock phase or equivalently the clock frequency (which except for a constant factor is the derivative of the phase to time) has random fluctuations causing the frequency of the played back signal to vary proportionally.
I'm rather sceptical about the supposed audibility, because even with a very cheap crystal oscillator as time reference, the variations are a lot smaller than those of the best analogue studio tape recorder. Still, many people hold a different opinion on that.
Reactions: Simon1972 and TNT
What if its a noise fold down effect?
Besides, its already noncontroversial that the published limit of audibility of jitter for a multibit dac is down around the level picoseconds or a few nanoseconds (which is at the level where it starts to sound like a distortion). Obviously that's still much smaller than the time deviation of tape wow and flutter.
It might. At least it's by far the grossest DAC imperfection I know. (Although you could also call it a mastering imperfection, of course.)
I think it's very unlikely to be the reason people think one DAC sounds better than another. But I'm not going to dismiss intersample overs as a non-issue. From a technical standpoint it's something that should not be happening.
It almost certainly is a non-issue. Watch this video:
Also, if one channel is out from the other by a fraction of a millisecond is that not going to be dwarfed by the fact you didnt match the speaker distances to your ears down to 1 nanometer?
I only watched a few fragments. As was to be expected based on the title, they have absolutely nothing to do with close-in phase noise, so it's clear that Miller-8 didn't understand post #89
Did you read my comment below the video?
Do you also have evidence of phase noise being a problem with DACs and of the more subjectively highly rated DAC having less phase distortion?
The problem with the term "jitter" is that it lumps together the effects of close-in phase noise, far-off phase noise/the phase noise floor and non-harmonic spurs. Unlike Andrea Mori, I would be least worried about close-in phase noise (although it's always nice not to have it, of course), because noise skirts around the desired signal should be well-masked. If they weren't, analogue tape recorders would probably be unlistenable.
The phase noise floor and spurs can have quite an impact, especially in some types of sigma-delta DACs. Every picosecond matters there.
Reactions: bohrok2610
In post #93, you mean? Yes, I did. That comment also has nothing to do with wow and flutter.
You are again mixing up phase noise and phase distortion. Maybe Wikipedia does a better job at explaining the difference than Mark and I do:
https://en.m.wikipedia.org/wiki/Phase_noise
https://en.m.wikipedia.org/wiki/Phase_distortion
What's your source for this? Have you measured the phase accuracy of many DACs?
I already presented a phase noise graph of SMSL DO300EX which BTW according to the manufacturer has a new self-developed CK-03 clock processing circuit that greatly reduces clock jitter. But according to measurements this circuit lowers noise floor (thus increasing SINAD) at the expense of close-in phase noise. Topping D90 had a similar phase noise graph but that was due to mediocre Vref regulator with high 1/f noise.
But don't get me wrong. I view these bad looking close-in phase noise graphs as only flawed implementations. I have not claimed that they have audibility implications. I'm not even aware of any studies or tests that have shown ultra-low close-in phase noise to have audible benefits.
Reactions: Miller-8
