can DACs sound different if they both measure well?
can DACs sound different of they both measure well?
  • Yes, I know I can hear the difference
    Votes: 69 45.7%
  • I think I can hear differences sometimes
    Votes: 26 17.2%
  • Not sure
    Votes: 18 11.9%
  • No, they will sound the same
    Votes: 38 25.2%
  • Total voters
    151
ASR has their dac expert. He and I have had some discussion. He is not sure about some things that might be audible with some dacs. At least he is willing to say to say so. He's still thinking about it as far as I know.
There are also other people over there who are labeled as technical experts, some pf whom aren't really expert on dacs. Doesn't keep them from thinking they know more than they do.
BTW, a new study came out related to overconfidence. Attached for your reading pleasure.
Reactions: blistard
Feynman's complete talk itself is fascinating. Here's a transcript:
https://calteches.library.caltech.edu/51/2/CargoCult.htm
Another "audiophile" belief I've seen on ASR, and also promoted by manufacturers, is one I discovered when wondering if audio recording interfaces could be used to record ultrasonic sound (in a biological/mouse experiment done by an associate), as all current ones have sample rates of 96k and 192k as well as CD standard 44.1k. Audio interface manufactures don't spec the frequency response above 20kHz regardless of sample rate, and posters on ASR don't care about anything above 20kHz, but they sure want more and more sample points to "more accurately reproduce that 20kHz sine wave" that the higher sample rates give them. They just don't believe the Nyquist theorem.
The reliable solution to recording ultrasonics is to design the electronics from scratch or use industrial equipment such as National Instruments.
Reactions: Matt888
That is just digital clipping, isn’t it.
It's digital (or analogue, but usually digital) clipping due to an input signal that isn't clipped. A bad but common mastering practice is to normalize the largest samples to full scale, but the interpolation (or reconstruction) filter output may then have to exceed full scale in between the samples. If there is no headroom for that, the DAC clips.
In my experience, two exactly the same DAC circuits (AD1865N-K NOS DAC) do not sound the same depending on the passive elements used in the construction. Mainly the electrolytic capacitors, resistors and wiring were changed from sample to sample, while the active elements were identical. I wouldn't know about two different DAC devices measuring well. I don't have the proper equipment to measure THD and such.
Reactions: audiobomber
But when a DAC is measured it's measured at the analogue outputs so the signal has already been through all those caps etc. The measured distortion is well below audible range so why would changing caps to more expensive ones help? It makes no sense.
I didn't use coupling capacitors on those DACs, only DC coupling. All those (small) differences are from electrolytic capacitors in the power supply. Some were made with Nichicon FW, Elna Silmic 2 and similar, and some with Samwha WL, Panasonic FC/FR and similar. There is quite a big difference in price.
Some things really don't make sense, but they are heard. I don't bother with it much.
Reactions: jean-paul
I know a lot of people don't like Amir at ASR but he's done a YouTube video where he shows a really dirty AC mains signal and feeds it into a Topping DAC and the DC signal that comes out it's power supply is ruler flat, and the distortion measurement is the same with the normal AC power signal or the deliberately distorted one. Changing caps like that does not affect sound. What it tells you really is that the placebo effect is strong and anyone can be fooled by it so be very careful.
No. That show's that the psu filters in the Topping DAC are well engineered. If he measured a stock Topping DAC, then took out the psu and decoupling and coupling caps, measured their parasitics and then changed them for other caps with the same capacitance but different parasitics and then measured the DAC again and the measurement results were exactly the same, then you could assume that the capacitors do not affect sound.
What would cause this presumed time difference between the channels?
Besides a time difference in microseconds would mean a difference of 1 or more samples at 768kHz. Would be very easy to see in measurements.
