What's the white stuff?
Joined 2019
The attached is the back of a USB hub that stopped accepting power from the wall wart. I took it apart because I can't help myself and was wondering what the white stuff was on the hand solder on the board mount USB sockets. It's easily scraped off with a finger nail and I assume its flux residue, except that there's the more normal flux residue there as well and it's only on the pins that're connecting the socket case to the board.
Any ideas?
Also it's quite a juxtaposition between the supreme tidiness of the oven cooked smd and that messy hand solder. Though, that said, I do miss the opportunity to scavenge parts. I can barely see some of those capacitors, let alone desolder them for reuse...
DC jack came loose or has very tiny cracks in the solder joints
No, and not as far as I could see. The plug looked ok and was chucking out enough power and the hub functioned on host power provided there was nothing too demanding plugged in. The power socket looked ok too.
I was just curious why the white was only around the socket support pins. I'm not up on industrial soldering and thought there might be something to learn.
I'd planned to harvest a few of the usb sockets just in case I might need them (though for what I can't imagine). Otherwise it'd probably have gone straight in bin.
They might have hand-soldered the connectors. Probably used solder with no-clean flux. You don't technically have to clean no-clean flux off the board, but it's generally a good idea, at least in sensitive circuits. As you can see the flux residue can attract stuff and react with it.
Tom
