tannoy hpd295/8
This is also called the Tannoy Gold?
I did a miniOnken for those, using specs i had to measure. I have found measured numbers do not get me to the proper size cabinet as if starting from good factory numbers.
The cabinet turned out to be too small (or noit tuned low enuff), they sounded decent, somewhat overemphasized at the bottom, i am sure the original XO committed many sins.
Trying agai, with a larger cabinet, would take some guessing. Might need a bit of vent tuning.
The additional data GM posted should help.
dave
Maybe I should try with Japanese cornetta reviewed in 6moons
plans are here
https://www.hilberink.nl/codehans/tannoy158.htm
It is bigger than monitor enclosure but maybe only way to go
as bass reflex with pleased result
Zoran
plans are here
Zoran
hello dave, i have just discover this page i see you have think about a Mar-Ken10.2TT do you have experience with it? what can expect in low frequency? vs minionken?
how tall it is? to see if it can fit me
thanks
thanks
I don’t know if it was ever built. Wouild require 4 x Alpair 10.2.
Colin did build the original rectangular for the A10(.1).
They have a false bottom, so as tall as you’d like. The Trapezoids are taller, the one for the A10.2 x 2 is just over a metre. That would work size wize for teh A10p, rthe A10.3 or MAOP 10.2 would be about 13/17ths the height (vents would need to change in both cases)
The driver smost often used in the microTower have more bass extention potential (how much depends somewhat on the driver used), and the cabinet is desogned top push bass extention. Probably lower than any MK10-something except for the A10.2 which was the bass extention champ which might go as low — until the A12pw came out.
dave
dave
Could you explain the 'subscription' plan. I'm a bit confused as to why I'd need a subscription to a schematic rather than just buying it, or is it just semantic?
It may be best to use a figurative example. Let's say I'm interested in a MA CHN-50 version to build, or rather convert to a 3D printable version. What do I need to fork out to get the schematics?
Most people consider it a “buy” but you have bought all the upgrades/expansion to any planset you buy so i call it a “subscription”.
dave
dave
These are sharp.![]()
I’m wondering about the best way to elongate my microTower build. False bottom or on a heavy plinth.
I can guess F6 and F10. F3 is meaningless unlkess there is an active XO involved.
And given that there is an extrapolation beyond whatthe simulator gives (it does not account for the high-R vents), F3 is hard to estimate.
dave
dave
MicroTower uses the floor. So you could well lose bottom if you add a fake bottom.
dave
How would I go about ordering, or commissioning a set of plans for a mini Onken for a pair of Goodmans Axiette II 8" wideband/fullrange drivers?
Cheers
Grant
Cheers
Grant
planet10
Sorry for the bad English, but I only use google translate.
I bought plans a long time ago and I bought the speaker back then. (FF-85WK FF85WK Fostex )
I only have two pdf documents of the plans.
I am willing to buy the plans again.
Please help.
Please help.
Hey,
Send me an email, we will sort it out. The most recent planset is dated May 2017. ou ar emissing a whole lot of the planset
And those drawings have lost the title blocks
dave
dave
I found your original order. Old emails thou.
When i get an emailwith your latest address, i will send planset URL.
dave
dave
- More Vendors...
- Planet 10 hifi
- planet10-hifi miniOnken Plan-Set Subscriptions
