Question about bracing of bamboo cabinet
I found a spruce plywood. Is that good? Any comments?
Noy surte.The firt looks like the blocks in the core are longish “sticks”. What we used used cubish blocks, What is most impoertant are the structure of the veneer layers. In order of performance, horizont, vertical, or stranded (strands embedded in ome kind of epoxy-ish binder. I’d not use the first. Second is most commonoy used, the stranded is quite a bit better and has a surface that is really hard to ding.
dave
