Hi
I'm looking to recap the crossovers on my Lentek S4s.
Trouble is I can't identify the caps or easily make out the values.
See pics attached.
See pics attached.
say what...? from left to right 4.7, 6.8, 3.3 MFD 100 volt aren't these polyester? don't see why they would be bad.
the coils are much more mysterious....unless you happen to have an inductance bridge.
hope i'm wrong but it looks as though someone used the wrong solder to touch up some of the joints...sad times now i bet.
That's just it I can't tell which are coils and which are caps.say what...? from left to right 4.7, 6.8, 3.3 MFD 100 volt
Just always been advised to change caps. Are polyester much longer lasting than the electrolyte ones?aren't these polyester? don't see why they would be bad.
I'd just like to stress that the yellow film capacitors will not deteriorate over time and consequently do not need replacing.
- Lentek S4 crossovers
