Transformer: 2x25V 300VA
Output Max: 56W into 8 Ohm
The opamp OPA453 is a TO-220 7pin device.
Which can have max +/-40VDC supply.
With the above transformer supply will be like +/-35VDC.
So if you make a really stunning amplifier for Winnetou, the great Apache chief, then I'm in. I would like to have a 100Wrms Monster (Apache) with nominally 4-ohm speakers.
Without OP amp, unless it is completely discrete built -please.
@hbtaudio
The input and VAS voltage amplifier stage can use a massiv number of transistors.
Making it more than half of an amplifier.
All this can be replaced by one opamp. This is what I do. And it works .....
Call one of your amplifiers Winnetou. That is a great idea 🙂
Beelzebub is not so nice 😀
Sounds good, matching transistor types make more sense for diamonds.I think I'll start a small series with the Germanic tribes too
with BJTs
And more devices for lower impedance like 4 ohm
This is a really good point.The input and VAS voltage amplifier stage can use a massiv number of transistors.
I have recently been wondering the same. Why is the op amp approach not so common to see? Are there technical reasons?
I think it is just more fun with transistors.
To design for yourself.
But this is not always for the better.
- Chippewa - 56 Watt OPA453 with Diamond Buffer output
