Jeff Bagby Designs - still available or still to build?
Most of his designs are small speakers unless I’m mistaken; I built the Revolution mini and liked it, and within limitations of a 1/4” cu foot cabinet, it was good one; I think his “trick” was using a 4 ohm mid-woofer for good voltage sensitivity of around 85dB/2.83V/m, and getting the right bass/treble for medium levels, at least in the medium sized room I was living in at the time.
Did Jeff declare that he liked the Helios the most?
Was was it the bigger (biggest?) of his released designs? If this is the case, I find it that interesting. Coincidence?
In some photos you can see other speaker in the background, including a 3 way design with some bright coloured drivers. What this his reference?
The man, the legend. RIP.
Of 3;
Spirit Winds
Helios
Continuums (original)
Middle ground;
Tributes
Revolution (Mistakes I preferred, and not)
That said, these are no slouch;
Quarks
Dreydels
Mandolin
Piccolo (vented I preferred)
Sopranos
LIghtning
Dayton RS-MTM
There was a Morel MTM at one point, don't recall the name.
He also designed the Helix MT and MTM for DIYSG. I’ve built the Helix MTM and I LOVE the frequency response and authority. They sound similar to my friend’s Perlisten towers, except with more bass and slightly more treble extension.
They’re not great at throwing a holographic soundstage though, and the vertical listening window requires you to have your head in a vice. I’m desperately trying to learn about the Helios’ vertical off-axis response and imaging and soundstage for this reason. In all other things, it seems like my perfect speaker.
