Hey,
Trying to find a replacement for 12" woofer:
-Made in middle of eighties
- low fs, plays 38hz in 70 liter vented box
- foam surround originally
- really cheap at the time
- back metal]=
case looks similar to Eminence
What about finding the sensitivity, that won't be easy. Are you going to be able to make adjustments.. what kind are available?
The manufacturer of the active speaker ask €€€ from the replacement if they even have itWhat about finding the sensitivity, that won't be easy. Are you going to be able to make adjustments.. what kind are available?
Looking for model& specs that i can buy it second hand or replace it with more modern driver ( with more RMS) The original driver is suffering when playing the active speakers loud
