Change power supply voltage for Audible Illusions 3A preamp
Hi all,
I got an Audible Illusions 3A with 120v power supply version. Now i would like to change to 220V power supply.
Does any of you have done it before or does any of you have the its PSU schematic diagram?
Thanks and regards,
Hi. Maybe transformer has two primaries, whose are now connected in parralel, wire them in series and you get 220-240V version. Check all windings with ohmmeter, write all info, and use a step-down transformer 220-120V , and connect preamplifier through it, then measure all voltages.
Reactions: theanhngn
Questions like this should always first be asked to the manufacturer before doing any action. This is the shortest path from A to B in many cases. Handy guys like found here have to guesstimate by looking at pictures while the manufacturer knows what he has made/designed.
The transformer on the picture seems to have only 120V primaries and many secondary windings but looks may be deceiving. The manufacturer can tell for sure. A 230V version will be an expensive one to have made and even if a member here gives the measured voltages you will not be sure what the intended voltages were by design. It will also probably/likely be more expensive than buying a 230V EU version (never choose a 220V version, mains voltages tend to go up not down) from the device producer. If it exists that is, it could be a US only device. Again something the manufacturer can tell. Therefor the advice wheezer gave seems most logical, affordable and efficient.
Advice is also to use PCB connectors and not solder wires directly to boards as the manufacturer did. Today that is considered plain bad practice for various reasons and no quality manufacturer does this today. How is one supposed to get the board out of the device made like this? Since the mains wiring is also too short you could consider using a Schurter IEC inlet with built filter (right current rated!) and benefit from the longer length and then have adequate length of wiring. Use 6.3 mm crimped faston connectors and don't make the same mistake by soldering wires. Clean power is a joy, no drawbacks.
Audible Illusions
7066 Commerce Circle
Pleasanton, CA 94588
(510) 463-9191
Apparently they moved.​
Phone
386-676-2004 Business Office
Webmaster
ml@audibleillusions.com
Mail
PO Box 2505
Ormond Beach, FL 32175 USA
E-Mail
info@audibleillusions.com
sales@audibleillusions.com
Yes I understood. That IEC inlet with built in EMI filter will give good results certainly with today's polluted mains voltage. Choose one with the same hole spacing. These do differ from brand to brand. If you know the drawn power to be below let's say 300W then choose a 3A version.
Please report here what the answers/results are. You will maybe help out someone else with the same question. The surprising answer may be that it does have 230V windings and only a few wires need to be rearranged (the PCB indicates that). Green to 6, yellow to 5 etc. That would be wonderful news, an efficient and affordable solution for you and interesting to know for us.
Thank you.
BTW USA companies tend to be safety freaks fearing death and destruction of their customers so make sure you tell them you are competent/certified. Of course only if you are competent or know someone that is. I recall ordering completely insulated click in modules at one manufacturer and the order was refused 🙂 Only after a written statement with signature I could order.
Reactions: theanhngn and cumbb
Thank you.
Surely do.
