RIAA Phono LR correction
Изготовлен мной с минимальным количеством конденсаторов. Я считаю, что именно они негативно влияют на звучание. Устройство состоит из 2 блоков - блока питания и самого корректора.
Which is about the architypal "negative effect on the sound"!
Many copies have already been broken on the topic of the influence of capacitors . There are already so many types of them created in prices from a cent to hundreds of dollars apiece . To some extent , profiting from fans of good sound . But gold capacitors also have an impact on the sound. Therefore, the radical solution is to get rid of this interference, not to apply them. something like this.
and what are the differences that apply to the useage of inductances instead of caps?
Are they less non-linear than caps?
Do they have a lower number of parasitic elements?
Do the parasitics impact less on the signal?
Well, we all know the answer is 3x no.
Which leads to the conclusion that they ´sound´ off of neutral ... or ´magical´ as You like to call it.
jauu
Calvin
Все эти предположения ложны.
On the one hand, I am happy for you that you have your own opinion on this. On the other hand, I feel sorry for you that you find this a delusion. I have made several custom phono amplifiers using different designs and different components. And I have an idea of what the sound can be. I do not pretend to be an absolute statement. This is a forum, right? So there may be different opinions. I respect yours, although I know that you are wrong. I have been designing for a long time. More than 25 years. I will post several photos of correctors and an amplifier that I made earlier.0_67711_444bf4b8_orig.jpg1.jpg.fe0706ecc0a7e7a8b3da1b7d99893367.jpg
I have no task to convince you, stay where you are. Just then explain to me - why the sound from one corrector causes skin itching, and from another sends you to nirvana. The TND of both is less than 0.1 percent. and why did AN release the M10 for such a lot of money with such complex components as inductors. Although they could have installed a couple of capacitors for $1
Price: £105,600 ($137,280 at time of printing) M 10 .
