When low HD is low enough?
Why do solid state amplifiers that have been driven to the lowest distortion values usually sound, and still sound, often much worse than, for example, tube amplifiers with higher distortion? The developers and testers don't look at the effort and complexity: low-distortion circuits are highly complex and often end up with a large number of amplification stages. Tube amplifiers rarely have more than three or four, the number of parts is lower: fewer parts modulate the signal with their character. In addition, even in the PP range, tube amplifiers are not built from highly different sounding complementary parts. Their separately amplified half-waves therefore sound more homogeneous. Real half-wave symmetrical pp concepts are very rare in the solid state sector. Unfortunately, the usual peep measurement values do not correspond to the audible measurement values. And simply claiming that an amplifier sounds more correct, because it distorts less, even if it sounds terrible, but the audible noises and signal modulations caused by parts are not visually detected and taken into account, is unscientific. Because "sound", "audio" can only be detected by listening, "audio"-)
It is difficult but I know for certain that your taste is so different from mine or anyone else that it is unimaginable that we can appreciate the better side of life. It boils down to saying I like being rich you will say that being poor is a more honest way of life. Or I say I like driving a BMW X7 and you will tell me that a bicycle is better because it is cheaper and gets you to the same destination....... ? Besides Jan, it is very unappropriated to allege what my limitations are, you have no idea. BTW the uniform that I am wearing is that of a major general and it was not given me by Xmas father. Besides the medals are actual battlefield decorations and none for long service.
I test the parts for their sound before I use them. 9 out of 10 parts are unsuitable for audio;-)
Meanwhile I assume that there are a lot of people who can't hear differences, just as there are people who can't tell the difference between green and red, or concept and object, for example. So it makes no sense to talk about different sounds of different parts. Or physics, or science or whatever;-)
When I worked for HP Signal analysis division, we had semiconductor components pre-selected according to our criteria by the manufactured labelled with HP part numbers. The reason was that if you design a signal generator there cannot be distortion in its output. Likewise for the linear amplifier in a network or spectrum analyser amplifier section. Not being in the position to order the exact characteristics from the outset must make testing and characterising components suitable for your design a tedious task and should fetch a high price for the finished product. I only made one amplifier like that and had all the metal machined and anodized, when finished I could hardly afford it. It revealed zero distortion, really. It is my pride and joy and drives my appogee schintillas with heft and dynamically only having 1 ohm impedance. I could not do this with tubes because I needed very expensive transformers made,
Reactions: 405man
Hire this man!
