Who can upload the schematic diagram from the plate amplifier (PCP-No E162886) of this model ?
Identical with Rythmik Audio Subwoofer Amp.
The driver comes from ISO acoustics (Model 13BH-10024SA)
Contact Us About Our Ultimate Speaker Stands
History of Leema - go to
Leema Acoustics – Alex Giese GmbH
Currently there are products in other kind available:
Leema Electro Acoustics
first time online 2002:
Wayback Machine
Wayback Machine
Is it not working? / What is not working?
Seems like an ordinary class AB amp with dual output transistors
Not hard to find failure.
No special circuit (only ordinary topology) and no special parts.
Creating own circuit drawing and perform repair is an easy task for me.
Nevertheless I want to have genuine schematic for a friend (for better sales opportunities).
Your image helped me identify a resistor that blew thanks!!
If anyone has the schematic that would be nice!!
I have an Anthony Gallo MPS-150 with the same board.
Looking at this imade brought back memories of this Class-D plate power amplifier underHello from the UK,
Sorry to trouble you, but have you managed to get the schematic diagram for this board? I have the same board in a Monitor Audio RS12 subwoofer, and having that information would help me understand how to repair it.
Thank you!
For this modul (PCB card naming "104-DS15000V-E") - go to
DS-15 104-DS15000V-E Digital amplifier module on 100surplus.com
and
Harman Kardon JB?L Infinity Subwoofer PCB Card 051 B00012A E 104 DS15000V E | eBay
I want the name of manufacturer, a schematic diagram and the reason for a lot of trouble in some subwoofer-models so as the right modification steps to get more reliability.
In follow subwoofer modules, which I know, this class-d card is in use
1) Harman Sub-TS11
2) JBL CSS10
3) JBL Sub-160
3) Harman TS2BQ
Follow German threads mentioned the trouble with it:
Heco Sub...
and
1) Harman Sub-TS11
2) JBL CSS10
3) JBL Sub-160
3) Harman TS2BQ
Heco Sub...
- tiefbassuebertr
- Forum: Class D
Absolutely short-lived due to faulty design and/or inferior component quality.
When I looking for powered subs in used condition, I still prefer class AB and normal 50/60Hz transformer like this one under
I recently bought a 2nd hand Hypex HS200 with a Shiva III to build a subwoofer (http://matthew.augier.info/index.php?album=/DIY/STS_II) from a guy who I trust to be honest. Got to the stage today where I wanted to test, connected it all-together and nothing. Everything is connected as it should be (green euroblock + to shiva+>+ and same with - side. But not a bean out of it. When the panel powers on in standby mode the light is yellow, and when sub sounds cut in it goes green as expected. So I tried another driver (8-ohm direct connect bsb-12) still nothing, which makes me think...
- Mat-d-rat
- Forum: Subwoofers
