Very good 8" driver that can be used to build a high quality sub
Could you share some info on these? Thanks! I have the same drivers to work with, and I'm wondering how to configure them
I have each pair in a 1.3 cubic foot box. I am using two DSA315 PR tuned to 31 hz. I used 400 grams on each if I remember correctly. They are still in test boxes, lol!
Reactions: Bryguy
Yes sir! No problem at all. That is the 6.5" midrange Purifi. I am using it from 200 hz to 1khz. Then the 50-1426SE takes over up to 4khz where the Bliesma T25B is crossed over.
Looks like a pretty awesome system. Never thought of playing the RSS210's so high, but looking at the spec sheet FR graph it looks like they are perfectly comfortable in that range
That TB dome is in some seriously high end company. Must be a pretty killer value if it holds its own among them
Reactions: analogkid455
Absolutely! It has incredibly low distortion, FR is flat as a pancake and it is the best I have heard in that range. I tried a lot of drivers in that range and I picked the TB.
