PHILIPS GM2317
Picked up an interesting 50s Philips GM2317 sinewave generator.
Beautiful large dial, great for my deteriorating eyesight.
I haven’t turned it on just yet, first I need for find a socket that would fit to this antiquated power inlet, I could hardwire it, but would prefer to keep the originality of it. It does look like one of those used on old kettles.
There are a few aged capacitors in it. Is there a procedure on how one could power up old equipment safely? Should I hook it up to my variac and increase the voltage 20V at a time, then let it sit for an hour, then another 20V, until it reach its operation voltage?
Reactions: tubelectron
Thanks Rayma, I had a quick look, everything seems to be in order. There are a few large capacitors in there, should I replace them first before attempting to power it up?
Unlike some old instruments which normally havens circuit diagram, there isn’t one in there.
Those electrolytic capacitors with the nipple on the top are usually fine and long lived.
I have got a resistance bridge with the same cabinet and dial and the capacitors were all fine most being Mullard mustard or there brightly coloured precision versions.
Reactions: NE WAY
Not our kettle plugs - they were big, round & had an extra pin with a big spring in the kettle to eject the plug should the kettle boil dry.
Usually into the kitchen sink - not a good idea for a live mains lead, eventually outlawed.
Reactions: NE WAY
