Hello,
I'm looking for some help finding some Shuguang EL156 tubes. Apparently they are not made anymore and are hard to find. Any help would be greatly appreciated.
Thank you.
Thank you.
Same pin-out as tubes like KT90. Any particular reason you want/need Shuguang?I'm looking for some help finding some Shuguang EL156 tubes.
jeff
Like Telefunken? Because they have a completely different base compared to Shuguang.Why not use true EL156 ?
jeff
Maybe because they have a standard octal base.Yes, but why use these "replicas" ?
jeff
Thanks for the response.A few are on eBay but horribly expensive.
Thanks for the reply. I saw this website but when you go to check out it says they’re not available z
Hi Jeff,Same pin-out as tubes like KT90. Any particular reason you want/need Shuguang?
jeff
I believe they are 8 pin instead of the original 10 pin. I’m looking for replacements for Eastern Electric M156 monoblocks.
I'm looking for replacements for the Eastern Electric M156 monoblocks. I believe the original EL156 tubes are 10 pin, the Shuguang are 8 pin.Wha not use true EL156 ?
- Tubes / Valves
- Shuguang EL156 Tubes
