I think it's better to have separate transformer for USB input and clean side for isolation.
Still trying to figure out what but aiming for a link between built environment business model continuity and environmental risks and opportunities scenariosCongratulations on embarking on the PhD. What topic?
Somewhere here on the forum there is advise to insert a diode into the 5V line of the JLS to lower the voltage a bit: I tried, since the heatsink stays much cooler.
If your Mico DAC build becomes a journey rather than a destination, as it seems to be for many of us,...
Ahaha, it is the club of the guys whom have 666 DACs already to be able to fill in the form with your blood ! 🤣
Is there a strong case for a separate transformer for iv and usb or should I order single transformer with 2x9 2x15?better to have separate transformer for USB input and clean side for isolation.
@hirscwi if you are going ahead with the GB for AD1865, I will be interested in 1 or 2 pieces.AD1865>>>
I've read all the discussion about the AD1865 over the past few weeks. Is the bottom line that they are available from DigiKey but you must purchase 13 AD1965N or 11 AD1865NJ? Or are there any legitimate places to purchase 2 or 4 of these chips? If there's interest, I could do another group buy for the AD1865 chip (I did one for the AD1862). If we need a group buy, what are the thoughts on through hole vs. SMD and N vs. N-J variants?
My apologies if this question has been answered - I tried to find the answer in this thread.
@voxxonline Digital interference between windings.
Note that the output voltage after rectification and filtration is
transformer output voltage * 1.4142
2x 9 ac == 2x 12.7 dc for regulator (if the output from regulator is 5V, you will need dissipate 7.7V x I into heat)
2x 15 ac == 2x 21.2 dc for regulator (if the output from regulator is 12V, you will need dissipate 6.2V x I into heat)
If the required output voltages from regulator are like +-5V and +-12V, and regulators are LDO type, custom transformer with voltages 2x5 2x10 will produce less power losses on regulators 🙂
+-5V and +-15V LDO regulators == 2x5 2x12 ac
Thanks, Miro. That's why I am thinking of getting lower-voltage transformers.
Shouldn' it be transformer (output voltage * 1.4142) - 1.4142?
So your recommendation is to get 2x5 2x10 for the DAC. DAC stage is on ubib- Salas is asking for 5V extra.
And another one for USB + Clock - both 5V?
And another one for a much later build of IV stage (it needs +-15V so I guess 2x12V would suffice)
Which regulator do you want to use?
If you use PSU2,you need +/-12v secondary.
For I/V if you use ubib or super regulator,you need +/-15v.or you could have another+/-15v for LR.
I used lt3045/3094 from woodturner-fran so I used from PSU2 raw psu.
It was great that small space with regs LR each.
I think it's good to have 2 transformers for USB and one custom for Dac+IV.
This way, it's easier to change or modding plan after build.
But I am noob so better ask someone for best way for sound quality.
Basically I have 2 ubib which I was planning to hook up to DAC digital and analogue.
I have unpopulated PSU2 which I received with your dac chips, Tamra.
Minutes ago I got delivery of several FlexReg boards.
I can mix and match psu in any order - if say digital or analogue dac side is going to benefit from shunt- it will go there. If shunt is better for IV- it goes there.
Same for other boards.
I wonder if wood turner -fran have PCB for IV,
It worked well.
https://www.diyaudio.com/community/threads/possible-gb-for-lt3045-3094-pcb-ref-smd-fc-cen-iv.402297/
It worked well.
If you want to know rectified voltage, this tool is amazing if you don't want to wreck your brain 😁
https://www.petervis.com/electronics guides/calculators/transformer-ac-to-dc/ac-to-dc.html
It calculates it based on diode Vf, so you can pinpoint more accurately and reduce heat output as much as possible.
@voxxonline exactly, the output voltage is == transformer voltage * 1.4142 - (2 * diode forward voltage) ....
calculate the voltages based on your regulators plus the asking extra voltage ... when using LDO based (PSU2) the safe extra is +2V (also can be slightly less) 😉
yeah it is good to have some margin, the heat makes the clock crystals to be Owen eated w/o aditional owen board hassle ! 🤣
Notice some well made R-Core could be lower than the Torroids or Ei-Core Power Traffo. the rule of 1.414 average often does not apply to them but with the marginn you are safe. Some prefer to have a unique power traffo with the number of secondaries needed with a fine adjustment of each winding made for the current needed by the load. I never found clear explanations about that and if someone has it will be appreciated 🙂 !
See curent as a thing that goes back to a secondary winding and sure you do not want to share a secondary with too much different load. Some to be sure applies : a secondary per load (could be expensive for true symetrical cirduits 😱
- Digital Line Level
- DAC AD1862: Almost THT, I2S input, NOS, R-2R
